Holley 1946 full rebuild kit
Gom212
Post #1 by Gom212 » Tue Mar 24, 2020 8:36 pm
I'm rebuilding my Holley 1946 carb 1v and as I was disassembling it i found that the I believe the needle where fuel inside pass the carb was broken. I was wondering if anyone knows if they sell a completely rebuilt kit for it that includes that needle. I don't how it broke but i found out why it was rattling inside. Its next to acceleration plunger and it has small holes on top near the tip. Thanks for the help
Econoline
Re: Holley 1946 full rebuild kit
Post #2 by Econoline » Wed Mar 25, 2020 1:22 am
What part # is it in this diagram?
http://www.chicagocarburetor.com/pdf/Instructions-Holley-1946.pdf
All carb rebuild kits come with a new needle and seat, but it sounds like you aren't for sure what it is.
It ain't gonna fix itself
Post #3 by bubba22349 » Wed Mar 25, 2020 1:36 am
You can try Mike's Carb's he might have some spares. I also have a nice low Milage 1946 carb off a Mustang. Good luck :thumbup: :nod:
Gom212
Post #4 by Gom212 » Wed Mar 25, 2020 7:59 am
It's not numbered or has a name on it, but you can see it on #26 the bowl cover assembly at the bottom that pointy spike. That's what broke it some how go corroded and just broke.
chad
Post #5 by chad » Wed Mar 25, 2020 9:18 am
"...spiky..."
the fuel tube? The (IDK, ah...) 3/16th ID metal stub tube feeding the fuel into the carb?
U can put another in, but if it's the top housing/case I think it's time 4 a new carb (well we take used round here).
I must B 'off' cuz I can't imagine brass or alu caroading/rusting & crumbling.
Mike's aint only good for all those rebuild prts, using his 'order list' can ID carbs & extrapolate back to Y/M/M'n displacement, watch a rebuild vid (by da man himself!) & more.
Gom212
Post #6 by Gom212 » Wed Mar 25, 2020 9:42 am
Yeah that metal tube in the housing that fuel pass through i clean everything and it seems every part is fine except for that piece, I really don't wanna buy a new one since I'm a tight budget. I also thought it was weird that it corroded that tube but the inside the carb there was lots of corrosion so I'm thinking that maybe water got into it or they added some kind of additive.
chad
Post #7 by chad » Wed Mar 25, 2020 10:00 am
find similar tube, saw off at place it joins the case, get progressively larger drill, clean it out & press fit ina new tube?
Don't crush case (carb top) in vice - line jaws w/copper, or have a friend hold ona bench, don't push hard, let drill do the wrk....) Gotta say it here: "You know the drill"
aaahahahaaa
:twisted:
~good luck, have fun, B safe'n productive !~
(w/apologies to Leo)
Gom212
Post #8 by Gom212 » Wed Mar 25, 2020 10:44 am
Yea i was thinking that, but there's no name for it so I'll have just have to keep looking. As for the kit who sales the best one out there? I'm looking for a kit that sell complete rebuild with check ball, plunger and all.
chad
Post #9 by chad » Wed Mar 25, 2020 11:25 am
most of us keep lauding "Mikes Carbs".
Grab a 'tube' on line or at ur local hardware store.
I just used a friend to hold 4 wooden finial I drilled so I could
re-pin broken off bed post tops. Any vice woulda crushed the finish
and wood fibers. Should B easier w/metal. BTW ask Mike, he has an e-
mail contact on his site. He gets right back 2 U ina few days. He may havea
idea or prt for the tube (off application able to put to good use here, not 'Mickey
Mouse' by any means).
Gom212
Post #10 by Gom212 » Wed Mar 25, 2020 11:55 am
I found out its called "Emulsion tube"or known as  the "high-speed air-bleed" where fuel and air mix in the carb I'll share the link the picture has it and you can see what it is. So yeah I'm gonna check if Mike's has it, hopefully he will or I'll just buy the top part of it that has it.
http://www.hotrod.com/articles/ccrp-080 ... ics-guide/
Post #11 by bubba22349 » Wed Mar 25, 2020 12:09 pm
You could try making one out of brass tube and copying the orginal. :nod:
Users browsing this forum: No registered users and 54 guests
