'53 Packard flathead IL8
luckykid
Post #1 by luckykid » Tue May 18, 2004 1:03 am
Does anyone know were I can get performance part for my 327 IL8 flathead. Specifically I'm looking for some sort of split intake to run dual carbs and possible headers. I have heard that Studebaker made the intakes and that they might fit the Packard engines, but nothing for sure. I'm also not sure where to get the Studebaker part either.
addo
Post #2 by addo » Tue May 18, 2004 1:30 am
Not an answer per se, but have you visited inliners.org?
Maybe some knowledgeable types on that motor, over there.
Cheers, Adam.
luckykid
Post #3 by luckykid » Tue May 18, 2004 1:57 am
Not yet. I'll try over there. Thanks
Fred
Post #4 by Fred » Sat Aug 28, 2004 10:01 am
In 1953, and possibly other years Packard offered a 354 (give or take 5 cubes) inline eight, with a four barrel carburetor. I don't know if it will fit your 327, but it sure would be cool if it would. It would be even better if you could find an original 354 four barrel motor. Good luck!
Lazy JW
FSP Moderator
Post #5 by Lazy JW » Sat Aug 28, 2004 1:17 pm
My brother used to own a 54 Packard with the 327. It had a two barrel carb on it factory stock.
Joe
"The White OX" 1974 F-350 300-6, Stock single exhaust, Carter YF, T-18A, Dana70 w/4.11, Flatbed dually w/dump bed. "Where no oxen are, the crib is clean, but much increase is by the strength of the ox" (Proverbs 14:4)
luckykid
Post #6 by luckykid » Sat Aug 28, 2004 2:26 pm
Mine already has four barrel on it. What I'm looking for is a split intake manifold to run dual carbs.
Seattle Smitty
Post #7 by Seattle Smitty » Mon Aug 30, 2004 3:30 pm
Check your bore-spacing, then see if you can adapt a couple of manifolds from 4cyl Datsuns or something.
Seattle Smitty
Post #8 by Seattle Smitty » Mon Aug 30, 2004 5:14 pm
oh, and connect the plenums with a balance tube.
