engine swap
81boxtop
engine swap
Post #1 by 81boxtop » Fri Mar 08, 2019 12:12 pm
This may seem like blasphemy to we Ford guys but has anyone ever swapped an AMC or Jeep inline six into a fox body? Maybe a late 1980's 4.0 this is injected?
Re: engine swap
Post #2 by bubba22349 » Fri Mar 08, 2019 1:14 pm
There have been the Ford 250 Small Six and even a few 4.9 / 300 Big Six swaps into the Fox chassis ducumemted on this site. So far haven't heard of any AMC swaps yet. Good luck :thumbup: :nod:
81boxtop
Re: engine swap
Post #3 by 81boxtop » Fri Mar 08, 2019 3:34 pm
I am not so sure that is the way I want to go but then again maybe... I first had the notion that I would just stay with the 200 in my Fairmont with moderate upgrades. It just keeps nagging at me that why go back to carbs when injection is so much better. It took me a while to be won over with injection but after owning a number of late 80's Mustang GT's and a couple of SVO's I am completely on board with injection. I don't really want just another V8 Fairmont and I like the challenge of something a little different. That is when I began thinking "outside of the box" . From what I have researched so far these AMC engines all have rear sump oil pans, so at least that is a good starting point. Of course there will be much more to it than that. I will keep researching and who knows maybe that is what I will end up doing. I just don't know yet. If I do decide to go that route I will definitely stay within the OBD I years. OBD II and beyond gets way too complicated.
Econoline
Re: engine swap
Post #4 by Econoline » Mon Mar 11, 2019 11:59 am
I had a 92 2-door Cherokee w/a 4.0 and 5 speed. It's a great engine. I considered the same thing when I swapped a 250 into my van. Ultimately I stuck with the ford, but now I'm wanted it fuel injected...
If you go this way, I think you should reconsider the OBDI thing though, I'd go OBDII. They built those cherokee classics until at least 2000 so there are ODBII versions.
It ain't gonna fix itself
bmbm40
Re: engine swap
Post #5 by bmbm40 » Mon Mar 11, 2019 8:03 pm
I use a 2001 Cherokee as my urban assault commuter and it really goes good but the Cherokee is a light vehicle. Mileage is not that great could be a malfunctioning component.
I have read about a Ford or GM tbi and Megasquirt with some fabrication of certain components used on the 200. At one time there was lots of tbi vehicles in wrecking yards you would think it would be possible to go shopping at picnpull and pick up everything you need except the Megasquirt for cheap.
NEXT- direct mount 2v, power brakes, rear LS, 3G, electric fan, electric upgrades, custom curved DSII, header, 31" tires
Re: engine swap
Post #6 by xctasy » Mon Mar 18, 2019 3:26 pm
Bore spacing makes the length of an AMC 232, 258 or 4.0 liter in-line six a little difficult.
The Big Six 240/300 4.9 liter has a 4.47" bore spacing,
JackFish wrote:Here's a 300 in a Zephyr.
It fits. Sort of:
the AMC is similar at 4-3/8 or 4.375 if I recall.
They take up a lot more room than a 200 or even 250 with a 4.08" bore spacing for each 6 cylinders.
Each is taller by far, the 200 is very shallow, the 300 and AMC 232, 4.0 liter and 258 very tall.
