fiddyfofoad
I've got an assortment of problems with my 54 223. First one I'm going attend to is the low oil pressure. First off I thought it was the pump, so I replaced it, at the same time I dropped a main cap, was not pleased with the condition of the bearing, plastigauged it and it didn't even touch it. Put it back together and got 12lbs at idle with 15/40, up from 2lbs. Dropped the oil and put in 3 qts 50w and 2 15/40. Got 15lbs at idle. Dropped the oil and put in 2qts Lucas, 2qts 70w and 1qt 50w. Got 22lbs at idle. I hope I can get away with doing the mains and rods in chassis because I'm not equipped to pull an engine. Rear rockers also clack when it warms up. Took the side cover off and saw that the rear oiler wasn't even in the hole. Put it in place, but at the time did,t know there was a grommet supposed to be in there. Rockers still clack.
Any one ever do rods and mains in chassis? How hard is it? Joe
