Next turbo victim
Turbo and Wastegate MasterPower T70 and 50mm wastegate
Here is the megasquirt adaptor board fits in the factory ECC IV case nicly. I only modification needed of was a couple strips of weather stripping to make the bottom of the circuit board from shorting out
fuel rail modified for SX fuel pressure regulator and guage.
Installed had to notch the intake a bit for the regulator
Runs good on the Megasquirt and 42lb injectors. Next up install boost, A/F, and fuel pressure guages.
