Well I've got a unique situation on my hands here fellas...the flange on my manifold is seriously warped, even with the new gasket it still leaks.  Apparently I've had this leak from the very beginning. Its quite large, if sealed it would likely drop my spool rpm by 300-500 rpm.  So how do I fix it?
As you can see in the picture below, I welded in the bolt threads, so there isnt much in the way of trying to resurface the manifold side.
The turbo side is flat (or at least a lot closer) so it'd be useless to try and resurface it.  No gasket or sealant I know of will hold a gap this large (can't quite see it on the truck but I'm quessing its near a 1/16th of an inch.)  Also, I dont have enough threads to use a really thick gasket, the nut wont grab the threads, or at least not nearly enough.
So the only option I see left, and I know it sounds kinda rash, is to weld the turbo to the manifold.  I'll pull both the manifold and turbo, leave them bolted together, and lay as small of a bead as I can along the joint.  Enough of a weld to seal the joint but hopefully small enough that if I ever really needed to separate them, I could grind through the weld in a reasonable amount of time.
Unless someone has some miracle gasket material I've never heard of that will hold boost pressure at 1200+ degrees F, this seems to be my only remaining option.  What you think?
