Header flanges for US Crossflow owners
'68falconohio
Post #1 by '68falconohio » Mon Jul 05, 2010 12:13 am
Alright guys, I just finished up a model in Solid Works for the crossflow.
I have a source with a CNC Hi-Def Plasma table and I'm going to see how it comes out on 3/8" mild steel plate. I don't believe that his table will do a good job on 1/2" plate as plasma cutting leaves a taper that's more prevalent as the matl. thickness gets larger than the hole diameter.
I'm going to try one on 1/2" though for those wanting to turbo. If the 1/2" plate can't be fully cut on the table maybe I'll have him cut the flange profile and port holes, leaving the boltholes to be drilled on the drill press with a 3/8" plate as a jig?
I know of one FSP member who's interested in header flanges but is anyone else interested?
Once I confirm fitment on my head, I'll post some pics. I'll have pricing then; they should be quite affordable.
'68 Falcon - sold
'99 F-250 Super Duty, '64 Lincoln SA-200 "Redface" - weldin' car
'04 F-350 Super Duty - racecar
MustangSix
Assistant Admin
Re: Header flanges for US Crossflow owners
Post #2 by MustangSix » Mon Jul 05, 2010 10:34 am
1/2" is kind of thick, even for a turbo application. 3/8" would be plenty, I think, and 5/16" would be sufficient for most other N/A uses.
Jack Collins
'68falconohio
Post #3 by '68falconohio » Mon Jul 05, 2010 8:09 pm
It seems the consensus on theturboforums.com is that 1/2" is a good thickness for turbo flanges; that's where my thought came from. I do not have any experience with turbo motors, just offering up this group buy on flanges because I have a good contact with a CNC cutting table. I'm going with 3/8" thickness on my N/A setup so that I can hit the flange on the belt sander to true it up after welding. Hopefully I have some pics of a good fitting flange by the end of the week.
'68 Falcon - sold
MustangSix
Assistant Admin
Post #4 by MustangSix » Tue Jul 06, 2010 1:33 pm
Don't get me wrong - 1/2" will work, but welding a 14 gauge or 16 gauge tube to a flange that thick will be tricky. That much metal takes a lot of heat to get any penetration. It'll take a good TIG operator to keep the heat directed to the right place. Other than that, I think it's just thicker than it needs to be.
Jack Collins
aussie7mains
Post #5 by aussie7mains » Wed Jul 07, 2010 7:55 am
10mm is the norm down here, and I wouldnt tig weld either, the MIG is better for that, TIG is OK for the other pipe welds if you really must have a speccie job.
I always laser cut my flanges unless they are thicker than 20mm which is the thickest that can be cut with that process, (less in ally) thicker is water jet.
A7M
MustangSix
Assistant Admin
Post #6 by MustangSix » Wed Jul 07, 2010 10:07 pm
10mm is closer to 3/8". I would think a MIG on such dissimilar masses of metal would be even harder to do.
Jack Collins
'68falconohio
Post #7 by '68falconohio » Wed Jul 07, 2010 10:40 pm
MustangSix, it's my understanding that most DIY turbo header builds are done using sched. 40 weld elbows and sched. 40 pipe due to the temperature and stress. 14 and 16 gauge mild steel won't live long w/out mucho bracing, AFAIU. If this isn't accurate, someone please let me know.
MIG will shine with dissimilar material thicknesses; torch angle and parameters adjusted accordingly.
If you're welding 1/16" material to 1/2" though, once fusion on the leg of the weld is greater than the thinner material's thickness failure is forced into the base material. To qualify a welder for Sheet Metal welding to AWS standards, they have to weld the sheet metal to a 1/2" plate in a T-joint configuration. By far one of the easiest tests because it's super easy to get 1/16" of fusion on the sheet metal and force the failure into the sheet metal.
I'll be TIG'ing mine.
Still havn't had a chance to drop by my buddy with the plasma table, hopefully tomorrow.
'68 Falcon - sold
MustangSix
Assistant Admin
Post #8 by MustangSix » Thu Jul 08, 2010 3:34 pm
Never built a turbo header, so you may be right about the Schedule 40. I think this is an area where my welding skills fail me. :(
Jack Collins
addo
Post #9 by addo » Thu Jul 08, 2010 6:34 pm
I'm hoping this thread will "grow" with some photos in progress of welding pipe to flange.
As someone with negligible welding skills, the more I understand what someone is supposed to be doing for me - the better!
XFlow_Fairlane
Post #10 by XFlow_Fairlane » Sun Jul 11, 2010 11:02 am
like I said before I would be down for a couple sets (4-6 prob) 3/8 is fine even for a turbo.
Rule: Torque = Fun , Turbo's make Torque
'68falconohio
Post #11 by '68falconohio » Sun Jul 11, 2010 3:54 pm
Didn't get the first one cut due to 80hrs of work. Will let all know when there's a good flange made.
'68 Falcon - sold
Invectivus
Post #12 by Invectivus » Thu Jul 22, 2010 1:09 pm
I'm interested, idea of what the cost would end up being?
1967 mustang coupe - 200ci, 69 dizzy, adjustable rockers, headers and dual exhaust, T5.
1964 convertible falcon - Gutted.
1973 EB Bronco - 302ci (sorry!) DUI ignition, C4/D20, Dana 44, 33's
'68falconohio
Post #13 by '68falconohio » Sat Jul 24, 2010 2:01 pm
My contact will be at Lake Cumberland on vacation next week and I didn't get a chance to talk to him this week(work in the way). Sometime the following week(Aug 2nd) I should get a day off of work.
The plan is to burn a test plate in some 16 gauge and check fitment on my head, tweak the .dxf, then get the real thickness cut. Once the .dxf is verified it should move quickly.
I don't want to put my foot in my mouth on the price, so I won't throw a dollar amount out yet. Will let all know when I get a fixed price from my cutter. Sorry for delay.
'68 Falcon - sold
'68falconohio
Post #14 by '68falconohio » Tue Sep 21, 2010 1:23 pm
Guys, I lost my .dxf..... when I quit my job. Since it was saved on the company jumpdrive I carried around I can't get it back. Worst yet, I used a milling machine with a dead center chucked up to plot each center point of the mounting holes and ports(worked great!, DRO's rock) but I brilliantly wrote everything down in my composition book which they now have. I'm still trying to get the .dxf back or at least all the centerpoints so I can remodel it. :bang: :bang: :bang:
'68 Falcon - sold
Bayrunner
Post #15 by Bayrunner » Tue Oct 12, 2010 9:21 pm
I need a couple. pm me please
Former Cars
69 Mustang Mach 1. Yellow
04 Mustang Mach 1. Screaming Yellow
03 Maserati Spyder Grand Sport F1
Current Cars
66 Mustang Coupe. 250 X Flow Conversion. 570 HP at Crank. Looking to break 700 with a larger Turbo.
08 H3 X -
3each Range Rovers for daily driving.
XFlow_Fairlane
Post #16 by XFlow_Fairlane » Wed Oct 27, 2010 9:47 pm
once you get a dxf file I have a line on a shop 15 mins from house that could do it.
'68falconohio
Post #17 by '68falconohio » Wed Oct 27, 2010 10:03 pm
I'm working on it again, will keep all posted when I get a dwg done again.
'68 Falcon - sold
59Orphan
Post #18 by 59Orphan » Wed Dec 01, 2010 2:49 pm
Here is a one flange I made for my 223 turbo header, but the 3 & 4 exh port need a divider. So I made another one. its 1/2" mild steel with sch.10 runners.
Some tIG welding and grinding.
Final Product.
This is a long term project so I have not got it out on the road, but it sounds awsome.
1959 F100 223ci
Turbo T3/T40E
Holley 4412
Petronics/MSD 6AL
and other stuff
'68falconohio
Post #19 by '68falconohio » Mon Dec 06, 2010 1:28 am
59Orphan, I can't see the last couple pics. :(
Crossflow guys, I have finals this week(should be studying right now, or sleeping?) then I'll have more 'free' time.
'68 Falcon - sold
64 200 ranchero
Post #20 by 64 200 ranchero » Mon Dec 06, 2010 2:57 am
cool, cant wait to see what you came up with
60 ford ranchero daily driver. 200 tri power, modified c4 trans, ds2 distributor, msd programable 6al2, weber ict's, 8" rear end with full spool, 3.80 gears, 245 tires, CI dual out header, Dynomax muffler, 114hp shot wet nitrous kit. JE Forged pistons, 280 110lc cam, around 11-1 compression.
59Orphan
Post #21 by 59Orphan » Mon Dec 06, 2010 2:46 pm
Ok fix it. And added a photo.
1959 F100 223ci
Turbo T3/T40E
Holley 4412
Petronics/MSD 6AL
and other stuff
'68falconohio
Post #22 by '68falconohio » Thu Feb 10, 2011 2:15 pm
OK, I learned my lesson on posting something before I had it ready, but here's a test piece. I burnt this out of 3/16" CS to confirm hole location and fitment to the head. The port holes are 1.530"(good to slip 1.5" tubing through) and the bolt holes are .410-.420". There will be a little bit of taper to the bolt holes when cut in 3/8" but I will ream them with a .420" bit before they ship. The flanges will be 3/8" CS, I will check on SS if anyone is interested. I will have more pics of finished flanges soon, along with a price per flange. I'm going to move two of the bolt holes .010-.020". The test piece bolted up fine, but they'll be better if I move 'em just a smidge.
The top strip is something we added to help keep the flanges from moving while welding. I can zip these off with a cut-off wheel if you do not want them, but I plan to take advantage of them and leave them there when I make my headers. The tabs that connect them are only about an 1/8" wide. Even though the top strip is there, I would still attach the flange to the head or another suitable working fixture when welding/fitting the headers.
Also, I have a .dxf now for the intake side. I havn't done anything yet to confirm its fitment or set a dimension for the diameter of the port holes yet. But if folks are interested, we can get a batch of them cut too. (This willl take me a little time, I'm very busy with school right now)
A BIG thanks to CNC-Dude for helping me get the flanges re-drawn. After I lost the initial drawing, he was a big help in getting the flange re-drafted. :thumbup:
'68 Falcon - sold
CNC-Dude
Post #23 by CNC-Dude » Thu Feb 10, 2011 2:33 pm
'68falconohio wrote:Image
Stephen, I just hated to see you being so close to having something with that much potential, and then having your files lost like that. Im glad I was able to give you a hand to get back to this point! I hope they do well for you. Thanks.
gravelrash
Post #24 by gravelrash » Sat Feb 12, 2011 8:01 pm
i can buy the header plates off the shelf down here. if you get the numbers up i could prob send over a few to you guys.
1965 XP Falcon.
250 2v Turbo holset H1C 600dp blow through Holley.
NOW 250 crossflow efi using Delco injection.
412hp at the f@#king tyres. YEAH BABY
'68falconohio
Post #25 by '68falconohio » Sat Feb 12, 2011 8:54 pm
How much are they down under?
'68 Falcon - sold
gravelrash
Post #26 by gravelrash » Sun Feb 13, 2011 6:04 am
i think i paid about $55 for mine.
1965 XP Falcon.
rocklord
Post #27 by rocklord » Sun Feb 13, 2011 1:53 pm
Two things to consider when purchasing from OZ, shipping cost and exchange rate.
1. Shipping could cost as much as the purchase price.
2. Exchange rate between Australia and the US favors the Aussies now:
What use to be $1.00US=$1.20AU is now $1.00US=$0.98AU.
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
XFlow_Fairlane
Post #28 by XFlow_Fairlane » Sun Mar 06, 2011 8:31 am
heck I am down for a couple sets!!
was gonna make up a shorty NA header maybe and then a turbo header or two.
I am looking for an intake flage for the stock EFI boss section. I have a spare I can take a rubbing from and send you.
Invectivus
Post #29 by Invectivus » Sun Mar 06, 2011 11:14 pm
me too.
6cylfever
Post #30 by 6cylfever » Wed Mar 09, 2011 1:55 am
I just got a 250 crossflow and would be interested in a header flange. Are you using hot roll or cold roll steel. Will it have enough meat around port holes to enlarge? Are you concidering a intake flange? The injection set up on my engine may not clear the hood and I might have to make my own intake.
300 ford crossflow in austin healy 5 spd
292 chevy six in 47 chevy pickup 5spd
4.0 jeep six in 1950 jeepster
4.0 alum rover in 1967 Mgb
1967 chevy caprice orginal 427
1941 chevy coupe with 327
1955 pink t-bird (wifes)
1951 anglia stock
'68falconohio
Post #31 by '68falconohio » Wed Mar 09, 2011 4:47 am
The mild steel I'm using is Hot Rolled, Pickled and Oiled. Stainless steel(304SS) is also an option if anyone wants it. I know you guys want to know a price per flange and I do too... I'm still waiting on the cutting house to give me a price per piece. I have a meeting with them tomorrow to discuss other work(employment), they should have it for me then. Once they give me a price, I'll give everyone a little bit of time to decide whether or not they want a flange and how many before I get a batch cut. I intend to cut 2-3 extras for crossflow guys that come about in the future. They are swamped right now with work but promised to work me in.
Intakes are definitely an option if anyone is interested. What I need from the folks wanting intake flanges are:
1) A rubbing or drawing for the injector scallops(dimension and location reqd). The head that CNC-Dude cnc'd for me was a carby head; there were no scallops and I don't own an EFI head to look at/check fitment with. If anyone has .dxf of the EFI head that they're willing to donate to the cause that would be just as good, if not better. I'd like someone with an EFI head to confirm that the flange I cut fits the head properly before I cut a batch. Rather than make everyone port the flange a bit to make it right, I'd rather it lined up correctly from the go. (XFlow', PM me if you can do the rubbing and I'll give you an addy to mail it to.)
2) What diameter do you want the port hole to be? I havn't had the time to check what standard tubing size is offered/what would be best. I would prefer to make the flange suit a non-ported head and the end-user would be required to port it for larger sized tubing if porting has been done. I think that makes the most sense for everyone.
3) Spec carby or EFI. I doubt the Carby guys want the scallops cut out in the flange and vice versa.
6cylfever, how much meat do you need around the port? Intake and exhaust? I don't have the revised .dxf in front of me right now or the sample flange we cut. The cutting house has my crossflow head and the demo flange. Some punk has my laptop that was stolen a few weeks ago with the majority of my work on it so I can't check. IIRC, there's at least 3/8" addl. radius around the ports, if not more. I will check on that and report back, if more is needed to satisfy everyone's setup it can be done, I just gotta know what everyone needs.
School isn't taking up any of my time anymore so I have a lot of free time right now...I may be leaving for some pipeline work soon though.
-Stephen
'68 Falcon - sold
rocklord
Post #32 by rocklord » Wed Mar 09, 2011 10:53 am
Put me down for one of the header flanges.
Dan
Currently Own
rocklord
Post #33 by rocklord » Wed Mar 09, 2011 11:00 am
6cylfever wrote:I just got a 250 crossflow and would be interested in a header flange........ The injection set up on my engine may not clear the hood and I might have to make my own intake.
What vehicle are you planning on installing the crossflow in? If it's a Mustang, you shouldn't have any problem. MustangSix installed one in his 66 and had hood clearance to spare.
Check it out here: http://www.fordsix.com/XFswap.php
Dan
Currently Own
CNC-Dude
Post #34 by CNC-Dude » Wed Mar 09, 2011 7:01 pm
6cylfever wrote:I just got a 250 crossflow and would be interested in a header flange. Are you using hot roll or cold roll steel. Will it have enough meat around port holes to enlarge? Are you concidering a intake flange? The injection set up on my engine may not clear the hood and I might have to make my own intake.
What size header are you considering. I looked back at my original file drawing, and these flanges can easily accomodate up to 1-5/8" tubing if you need to go that large. If you need larger than that, I can modify the drawing to fit whatever size you need, and give it to Stephen so he can cut them for you.
6cylfever
Post #35 by 6cylfever » Sun Mar 13, 2011 9:57 pm
'68falconohio wrote:The mild steel I'm using is Hot Rolled, Pickled and Oiled. Stainless steel(304SS) is also an option if anyone wants it. I know you guys want to know a price per flange and I do too... I'm still waiting on the cutting house to give me a price per piece. I have a meeting with them tomorrow to discuss other work(employment), they should have it for me then. Once they give me a price, I'll give everyone a little bit of time to decide whether or not they want a flange and how many before I get a batch cut. I intend to cut 2-3 extras for crossflow guys that come about in the future. They are swamped right now with work but promised to work me in.
-Stephen
Stephen I haven't torn down my engine yet. The exhaust ports don't look very big. I see your from Ohio, I'm asnowbird in AZ right now but will be back in Mich in two weeks. I'll tear down the engine there and get back with you than Marv
1951 anglia stock
XFlow_Fairlane
Post #36 by XFlow_Fairlane » Mon Apr 11, 2011 2:35 pm
any update on when these will be available?
Any chance for making some for a 1-5/8" tube?
XFlow_Fairlane
Post #37 by XFlow_Fairlane » Mon Aug 15, 2011 6:49 pm
found a local driveline shop that builds rides on the side. I dropped off my V8 S10 driveshaft to get shortened and will be talking to them when I pick it up to see if they cna cut me some SS 3/8" flanges for my header. I am going to have them cut for 1-5/8" tube (minor opening up will be needed for weld el's) I have a lead on a shop in Nashville that can do them but will be a little costly since I don't have a CAD file of these (no CAD at work....go figure) I am hoping to have something lined out by the end of the month on these.
I will update when I find someone who can supply these and with pricing. When I do have some cut I will mostly likely have an initial run done of half a dozen sets.
CNC-Dude
Post #38 by CNC-Dude » Mon Aug 15, 2011 9:18 pm
I got pricing in the neighborhood of $60.00 each for the 3/8" mild steel header flanges I drew up for Stephen for this Crossflow project. That was laser cut instead of plasma. Plasma sorta' introduces issues that aren't present with laser cutting making plasma a little less desireable as an option for use in this application IMHO. I also have intake flanges drawn and can make them available if anyone is interested in making their own custom intake manifold for about the same price.
ozjello
Post #39 by ozjello » Sat Dec 28, 2019 8:26 am
I know this post is old now, but wondering if anyone ended up producing the crossflow exhaust flanges?
Thanks,
Tim
CNC-Dude
Post #40 by CNC-Dude » Thu Jan 02, 2020 7:34 pm
Nobody ever committed to place any orders....
ozjello
Post #41 by ozjello » Thu Jan 02, 2020 8:49 pm
CNC-Dude wrote:Nobody ever committed to place any orders....
I'd be interested if its cost effective to run just one or two flanges.
CNC-Dude
Post #42 by CNC-Dude » Sun Jan 12, 2020 9:40 pm
I'll see if I can find my CAD file. It's been over 10 years since this thread was started. Thanks!
ozjello
Post #43 by ozjello » Mon Jan 13, 2020 8:03 pm
CNC-Dude wrote:I'll see if I can find my CAD file. It's been over 10 years since this thread was started. Thanks!
That would be awesome, thank you!
papawsfalcons
Post #44 by papawsfalcons » Wed Jan 22, 2020 8:48 pm
This crazy I was just on ebay for Australia looking at headers(extractors). Before ordering I will wait see what happens with the flanges.
gravelrash
Post #45 by gravelrash » Thu Jan 23, 2020 3:52 pm
are you the guy i tried helping on facebook?
i offered for you to buy the header flange off ebay Australia, send it to my house here in Australia and send it over to you.
Was this you Pawpaw?
1965 XP Falcon.
papawsfalcons
Post #46 by papawsfalcons » Thu Jan 23, 2020 5:15 pm
Yes it was me . I was really hoping to buy it in the USA. I was looking and can not decide what to do. I was looking at kits to make one and it seams like the kits are about as expensive as buying one made. Sorry for being sure of what I want to do.
