UPDATE: After having the Mustang Crossflow project on hold for WAY too long. I am really wanting to get this thing finished and back on the road! The head should be in the shop being built next week. Then I just need to bolt on the head, intake and exhaust and finish up all the little things.
Now for an electrical question. I am using an OZ Bosch 2 wire dizzy. The car used to have a DII system. So....
Out of the firewall there is a plug with 3 wires 1 went to the temp sender switch on the 200 head. There is no such switch on the xflow. I assume I can just leave this one off.
the 2nd one goes to one side of the coil.
the 3rd one goes to the oil pressure switch on the 200 and xflow.
then I have 2 wires that that I ran fron the battery and solenoid to the external DII box. I would like to use those feed the new elec fan that is going in. Is that OK?
What do I connect the 2 wires on the bosch dizzy to? I am thinking the old wire that went fron the firewall to the coil could be one but not sure about the other...Ground maybe?
