It's a typical over engineered Chrysler engine, with practically no stuff ups. It's much,much stronger than a even a forged crank 225 Slant 6, and is a far better basic engine than the 200/250 Fords as its got big block bore spacings with huge ports and a short stroke design that loves to rev. Its 5.75" rods are used in 270 Falcon 250 strokers, and Chev 383 small block strokers, and they are stronger than any other factory rod, better than Chev X-rods or the best Holden Group A 304 rods (based on Nascar 350 rods). Chrysler had to make 200 Weber carbed Charger R/T's to qualify as a series production race car for the 500 and 621 mile Mt Panarama Bathurst car race, so they homologated an E38 with 280 degree cam and 280 hp in 1971, and a 302 hp E49 for the 1972 1000 km race. Each used Aston Martin DB6 Vantage triple Weber DCOE's. The E49 made only 12 hp less than the fabled 314 hp 4 liter twincam alloy six, and made the 1972 Charger E49 the worlds quickest production six cylinder car for a few months before the 492 odd Ferarri 246GT engined Lancia Stratos did 14.2's with 190 hp in a 2200 pound pacakge. Asside from some Porsche 911 Carrea 2.7's, it wasn't until the 1981 BMW M1 and E12/E28 Aphina BMW B9 that a quicker non turbo six cylinder car was made in regular production. Although Triple Weber E49's were made in less than 185 variants,there were a lot of milder triple carb Pacer sedans, and Charger R/T's with the 248 and 280 hp versions. The stock blue printed 302 HP Charger E49's dynoed in a 295 hp net at 5300 rpm for sedan race events like Bathurst and Benson and Hedges. The factory rev limit was just 5500 rpm, even with a 306 degree cam and 133 mph top speed with 3.23:1 diff. But it could go to 6500 rpm with ease. Quarter mile for a 3000 pound 105" wheelbase Charger was 14.4 sec two up with half a tank of gas. The Aussie Phase II and III engines ran a M/Q code hotchpotch engine, a 351 4V GT HO  spec engine with 3500 pounds could only do 14.4 with a 310 degree cammed 1970 Falcon, and 14.7 secs in 300 degree 1971 Falcon GTHO. It was only above 120 mph that Chryslers hotest e49 Hemi 265 noticed the lack of 86 cubic inches and two extra cylinders. Both cars ran ER70H14 tires, similar diff ratio, but there was only another 11 mph at the top end with a 350 hp net at 5800 rpm 351. 55 hp was the difference. The net figures above were from Aussie Mick Webb and NZer Leo Leonard, sedan racers who built and blue printed Ford and Mopar engines.
It's based on the D-series US Dodge truck engine which was shelved before production back in 1965. Chrysler Corp in the US couldn't see an market for a Dodge Inline six bigger than the slant when there were LA and RB engines galore. As such, the Hemi 6 is an American design with Australian input via Chrysler Australia Prty Ltd. Engineer for the 215/245/365 engine was Mike Stacey. He went to America, did the lab work there, then arrived back in Australia to productionise it. Local Chrysler francise funding and guidance was via David Brown, not the David Brown tractor magnete from DB2-3-4-5-6/DBS , but an Aussie director.
The result was a canted valve I6 with huge valves, non crossflow head, 2.2 sq in of intake port area at the gasket face, and a short stroke , poor rod ratio, shallow six with 9.37" of deck height, a one size fits all 3.68" stroke crank and small journal Chev style 5.75" rods, crank and wrist pins. And a close to Chev L6  4.4" bore spacing, just 80 thou down on the 4.48" of the 240/300 Ford I6. It started as a 245 in late 1969 VFX Valiants, then came out as a rare 250 in track pack Valiant VG Pacers, and a 215 and 265 were added in the 1971 Valiant VH.
Only two problems with the engine. One is timing chain rattle, (and a remedial service up grade which put a Hilman 1725 chain tensior on the wrong side of the chain). The other is crank life due to the small journals and high specifc output and rev range of the bigger 265 six. Crank bolts are constantly loose on an engine that could rev to over 6500 rpm in triple Weber E38 and E49 spec.  That's it. Pluses are Gross power started at 145 hp for a 1-bbl 215, then crept up to 160 hp for the 2-bbl 245, 205 hp for a stock 265 2-bbl, then 216, 248, 280 and then 302 hp for the 2-bbl Pacer, 6 bbl E37, E38/E48 and E49. A stock2-bbl 265 would eclipse a stock 318 2-bbl,and used its carb. The 1970 4-bbl 60 thou over trackpack 250 E36 would do well over 195 hp,and used a Carter AVS 4-bbl carb to good effect.
Early fuel consumption problems were easily offset by the Hemis high performance. In 1977, and Electronic Lean Burn variant came out, and like the US ELB 318/360's, it was a good performer with good fuel economy. It ended up as a 155 hp net 2-bbl 4.3 in the 1982 CM Valiant.
Like the Magnum V8 rework of the last Chrysler 5.2/5.9 engines blended AMC technology into a Mopar engine, the 1987 on Xj Jeep 4.0 infuses a lot of Chrysler Valiant Hemi architecture..short stroke, large bore, small journals, good valve and port areas.
