Best 2100 size to use
StarDiero75
Post #1 by StarDiero75 » Tue Mar 19, 2019 2:32 pm
Howdy guys,
With recent problems with my weber 32/36, I'm highly considering putting in an autolite 2100 since I plan to use that when i put my modified 1980 head on it.
My question is, they come in a wide variety, which is thr best to use on these engines?
A 1.01 comes off a 221 V8, so size is very similar
A 1.08 comes off most small block V8s, and this is the one I've heard is the best to use.
A 1.14 comes off 351s
Then the 1.21+ are big blocks
Would it be best to ise a 1.01 or 1.08? I'm looking for roughly same economy and slightly more power. But least work on jetting.
Ryan
rocklord
Re: Best 2100 size to use
Post #2 by rocklord » Tue Mar 19, 2019 3:55 pm
This might help:
ci/CarbChoice.html#2V
Dan
Currently Own
1965 Mustang, 200CID, 3Spd
StarDiero75
Post #3 by StarDiero75 » Tue Mar 19, 2019 6:47 pm
Looks like 1.01 or 1.02 are my carbs. Thanks man!
wsa111
FSP Moderator
Post #4 by wsa111 » Tue Mar 19, 2019 7:11 pm
Ryan, till you install the 80 head, your A/F tester will be a valuable tuning tool.
The Autolite carbs can also use a Holley power valve.
If too rich at WOT you may need smaller PVRC under the power valve.
67 mustang,C-4, with mod. 80 hd, custom 500 cfm carb with annular boosters, hooker headers, dual exh.-X pipe, flowmaster mufflers, DSII dist. MSD-6425CL & MSD-Blaster 8252 Coil. Engine 205" .030" over with offset ground crank & 1.65 roller rockers. 9.5 comp., Isky 262 cam.
CZLN6
Post #5 by CZLN6 » Tue Mar 19, 2019 7:25 pm
Howdy Star:
Here are a couple more FYIs for you-
1.01 & 1.02 Were both used on 260 V8s
*1.14 were used on 1964 - '67, 289s and 302s
1.08 were used on 1968 -'73, 302s
*1.23 were used on 1967 to '70, 351s
1.21 were used on 1971 - '73, 351s
The stars(*) denote the earlier version and have different internals (K cluster)causing the later versions to run slightly leaner and cleaner.
All have annular discharge boosters. All are incredibly easy to rebuild. Jets are unique to Autolite except for the very earliest, from 1960 and earlier. They were Holley. Ironically, the Holley power valves are interchangeable with 2100 and are much more accurate and come in a wider variety. Stock power valves come with a rebuild kit. Most 2100s- 1.08 and earlier can be used with no changes (with the exception of cleaning and rebuilding) when adapted to a 200 engine. Slight variations to the accelerator pump arms may be necessary. 1.08s were used on a variety of vehicles with a 302 engine- from Falcons and Mustangs to F100s and Galaxies so internal adaptation was made by changing the internal K-cluster. So, for your use look for 1.01 or 1.02 from a Falcon for best internals for your situation.
Hope that helps you understand a few more details. Good luck.
bmbm40
Post #6 by bmbm40 » Tue Mar 19, 2019 7:42 pm
Very interesting information regarding the model numbers and the K cluster lean/rich operation. Good to know, thanks.
NEXT- direct mount 2v, power brakes, rear LS, 3G, electric fan, electric upgrades, custom curved DSII, header, 31" tires
chad
Post #7 by chad » Tue Mar 19, 2019 8:04 pm
keep it goin, guys.
Close to another sticky?
Nice tech info for our carbs § ?
or 'sm block engine §" ?
Chad - '70 LUEB on '77 frame (i.e. PS, D44, trapezoidal BB 9", 4.11), '69 250ci, NV 3550 & DSII, "T" D20/PTO, 2" SL, 1" BL, 4 discs, 33"X15", tool boxes, etc. Seeking: Hydraulic gear motor for Koenig pto. chrlsful@aol.com
StarDiero75
Post #8 by StarDiero75 » Tue Mar 19, 2019 8:10 pm
wsa111 wrote:Ryan, till you install the 80 head, your A/F tester will be a valuable tuning tool.
Its a wonderful tool. It's just gonna drive me crazy till i get the carb all tuned haha
So in your honest opinion, should i ditch the weber 32/36 and go to the 1.01 Autolite? I want something more user friendly.
StarDiero75
Post #9 by StarDiero75 » Tue Mar 19, 2019 8:12 pm
CZLN6 wrote:Howdy Star:
1.01 & 1.20 Were both used on 260 V8s
The stars denote the earlier version and have different internals (K cluster)causing the later versions to run slightly leaner and cleaner.
That is pefect man, thats good info. It helps, I'm already on the lookout for the carb
cr_bobcat
Post #10 by cr_bobcat » Tue Mar 19, 2019 10:03 pm
I would go with the 1.08. I loved the 1.14 I had on mine, right up until I cracked one of the feet off. Don't over tighten those old carb bodies....
Econoline
Post #11 by Econoline » Tue Mar 19, 2019 10:14 pm
I had a 1.08 from a 72 302 I was going to use on my 250 until I decided to go tbi.
It ain't gonna fix itself
CZLN6
Post #12 by CZLN6 » Wed Mar 20, 2019 1:25 am
Howdy back Star and All:
FYI- The K cluster is responsible for rich/lean of the idle curcuit, transition circuit, and accelerator pump volume. That leaves the low speed idle air screw and the accelerator pump linkage externally to tune. K clusters are marked with a coded stamp to a specific vehicle/engine application. A 1.08 destined for an F100 to Iowa would have a K cluster very similar in appearence to a 1.08 for a Mustang going to Arizona, but internally would be very different. We have found no key to the FoMoCo stamped code on the bottom of the K cluster. So, swapping the K cluster, for refining the tune is a shot in the dark, at best.
For all of the 2100s simplicity and beauty of function, fine tuning, to a certain extent, is limited.
Ironically, we have swapped on a bunch of different 2100s, 1.08s and 1.14s to my 250 and to Dennis' 200 and they all worked fairly well- dirt and all, no rebuild. Other than not being able to find main jets to play with the Autolite 2100s are great. And they weigh less than Holley 2300 and have no gasket line below the fuel bowl.
PS- Autolite jets are not numbered the same way Holley jets are. Another mystery.
StarDiero75
Post #13 by StarDiero75 » Wed Mar 20, 2019 2:39 am
Econoline wrote:I had a 1.08 from a 72 302 I was going to use on my 250 until I decided to go tbi.
You don't still have it?
StarDiero75
Post #14 by StarDiero75 » Wed Mar 20, 2019 2:42 am
CZLN6 wrote:Howdy back Star and All:
Very strange, so its more or less luck with testing K clusters?
I'm looking for simplicity so this sounds like the carb for me. The weber is a nightmare.
I do have a 1.23 i got off a 360, and i love how simple it is. Simplicity is a beautiful thing.
StarDiero75
Post #15 by StarDiero75 » Wed Mar 20, 2019 2:51 am
Just bought a 68 2100 1.08 off a 302 from eBay. Hopefully its good. I'll look into getting the holley/autolite adapter from VI now. I gotta also swap to a cable pedal as i dont think the mechanical pedal will work anymore
Econoline
Post #16 by Econoline » Wed Mar 20, 2019 7:27 am
I sold it a while back
Post #17 by xctasy » Wed Mar 20, 2019 7:34 am
I enjoy Real People who do Real Stuff and get there hands dirty! Ryan, great work.
The typical Theoretical Engineer who got his hands dirty is the ex Limey David Vizard. He found that 1.19 vs 1.38 (350 cfm 2bbl vs 500 cfm 2bbl), the kick in was at just 125 hp net at the flywheel. Result? Another 10 hp net. The 1979 2.8 Mustang got given a 1.14 2150 Motorcraft over the 32/36 based Autolite or Motorcraft part numbered 5200. Some where, another 4 hp , depending on what figures you garner.
The average venturi size of a 5200 is exactly 1.01. The reason it gives strange air fuel ratios is the primary and secondary circuits augument air fuel supply. The carb on the 2.8 was well sorted.
My vote is for the old 1.23 with s two stage power valve and you play with the PVCR's with either Bills E string, fuse wire or Sean Murphy style hex plug and fine drill holes.
Econoline
Post #18 by Econoline » Wed Mar 20, 2019 8:02 am
Btw, jets for the 2100's are available.
https://www.carburetor-parts.com/Jets-_c_1607.html
chad
Post #19 by chad » Wed Mar 20, 2019 9:39 am
Good ol Mike's.
Not sure if U wanna look here but there's several threads on 'goni cable' w/o the Lokar.
(how 2 bend the pedle's arm, attach to fire wall, link it up on the carb...
wsa111
FSP Moderator
Post #20 by wsa111 » Wed Mar 20, 2019 2:21 pm
xctasy wrote: vote is for the old 1.23 with s two stage power valve and you play with the PVCR's with either Bills E string, fuse wire or Sean Murphy style hex plug and fine drill holes.
The orifices under the power valve can be drilled all the way & tapped close to the length of the 6-32 brass hex set screw.
They can be purchased at McMaster Carr. They come blank & you have to drill the desired orifice size yourself.
StarDiero75
Post #21 by StarDiero75 » Wed Mar 20, 2019 3:33 pm
xctasy wrote:I enjoy Real People who do Real Stuff and get there hands dirty! Ryan, great work.
Thats very interesting. I have a 5200 sitting in the garage and it looks a little smaller than the 32/36 i got, they might be the same since I've never measured them.
I can test the 1.23 i currently have on it and see how it does vs the 1.08 i just bought and see how they compare. I'll have the funnel adapter for a bit till i get the 1980 head set up for a direct 2bbl and i won't have to screw with adapters anymore. I'm hoping the 1.08 will do just fine.
Also, side question, if the AF gauge was too close to the manifold, would it give different readings vs being a little further downstream? I was looking at my sensor and noticed its about 10" from the manifold. Is that too close?
Post #22 by xctasy » Thu Mar 21, 2019 3:48 am
Ryan, you need to check the Innovate and AEM manual. And then set the Average exhaust runner distance at 12".
Then follow Chads copied detail in his footer 1/16/2017.
One change at a time.
Your conclusions on 32/36, 5200, 1.08 and 1.23 are purely subjective. There are 13 generic types of 5200, with four different venturi types, two different kinds of idle circuit, and it sat on over 5 different kinds of US domestic engine from 1600 GM, 1700 Chrysler, 1700 VW, 1600, 2000, 2300, 2800 Ford, AMC's VW Audi Porsche derived Fox 80 2 liter four in the Pacer.
Circumstances alter Cases.
Where you hook the vac line and vent tube defines advance curve and intake charge dillution, and they define more than jetting how an engine combination runs. Fuel pressure and cleaness of thr fuel system, and little things like throttle set up are played against curb idle position. A 5200/5210/5220 Holley Weber has American profile well tubes after 1974, and the jet size to cc/min or Micron stamping has not got a 2.54 metric to Imperial ratio because of how Holley profiled Weber jets. You'll learn all this stuff. Have fun.
The Holley Weber can potentislly kick any Holley 350 cfm or 0.98 to 1.23. A Holley 500 kicks every other carbd a$$ if your in the 125 to 225 hp bracket. You just have to follow David Vizards SOHC Ford carb details dating back to 1977 to 1988.
Enjoy yourself.
CZLN6
Post #23 by CZLN6 » Sun Mar 24, 2019 1:19 pm
Howdy Back Star and All:
"Very strange, so its more or less luck with testing K clusters?"
No. but you will need to know what the application of the 2100 was, from the factory. The 2100s are marked with a stamped code on the mounting foot of each carb. The K-clusters are not stamped but have code mark on the base of the cluster. To date, the code is unknown. But, If you know the specific application you will have a good idea of the characteristics of that cluster. You will need to know- vehicle, weight, elevation, transmission.
Assuming elevation and tranmissions are the same, if you are using a 1.14 from a '65 Mustang and you want a richer idle and transition, swap the K-cluster for one from a '65 F100 with a 302. If you have a 1.08 from '68 Mustang with a 302 V8 and you want to slightly richen the internals try swapping the K-cluster from a 1.14 from a '67 302 Mustang. This much is not guess work, well maybe an educated guess. Will this method put you spot on as with an analyser? No, but it will be closer. And swapping K-clusters is a whole lot easier and cheaper than buying an A/F analyser and figuring the internal restrictions for idle and transitions. And, what and adventure.
So, keep us posted on your choices and your progress.
chad
best 2100 size to use/how equiped
Post #24 by chad » Sun Mar 24, 2019 9:52 pm
"...The 2100s are marked with a stamped code on the mounting foot of each carb. ..."
& this is where Mike's comes in again.
U can ID the vehicle thru ID the specific carb. Compair the #s/Ltrs to the make/model/yr of vehicle listed w/that carb (like cross referencing in a way). This way U will not -example- try 1 for a heavy torino (also w/an off displacement, as listed, like a 428) for ur lght falcon (or whatever).
CZLN6
Post #25 by CZLN6 » Mon Mar 25, 2019 11:53 pm
Howdy Back:
Yup, Mike's is a good ID source. In addition to the stamped foot all factory carbs came with a metal ID tag with a code for dating, application and other info. Unfortunately, the metal ID tag frequently disappears on the first rebuild.
Hey Star- how's your progress?
StarDiero75
Post #26 by StarDiero75 » Tue Mar 26, 2019 12:28 pm
CZLN6 wrote:Howdy Back:
Still waiting on the carb from ebay. It should be here today or tomorrow. I'm also waiting on the correct adapter for it too.
I have the cable pedal to put it all in too, but thats gonna take a bit to fab to make work. Maybe Thursday if I'm feeling creative lol.
I'm kinda half tempted to just throw it on the car and see how it does rather rebuilding it. Heres what it looks like, its pretty clean which is why I'm considering that
bmbm40
Post #27 by bmbm40 » Tue Mar 26, 2019 7:06 pm
It looks pretty good I would also be tempted to try as is.
chad
Post #28 by chad » Wed Mar 27, 2019 10:36 am
I thought U already knew it wuz "too big"?
(See subject line above)?
Only 'rebuild' needed is change out internals 4 ur engine...
Do U have all these prts on hand? Will all these prts (carb, jets, etc) B @ ur home at the same time? If so avoid a double instal (install find it is not as should B, remove, correct, reinstall)?
How much of this carb can B done installed. Ur 32/36 - much could B done while mounted. This one? not sure (acc pump, all jets, etc)?
CZLN6
Post #29 by CZLN6 » Wed Mar 27, 2019 3:20 pm
Howdy Star and All:
I vote for putting it on and giving it a try also. Worst is likely a stuck needle valve. let us know.
StarDiero75
Post #30 by StarDiero75 » Wed Mar 27, 2019 3:23 pm
CZLN6 wrote:Howdy Star and All:
Just got the carb today. Its real clean and everything seems to move very nicely. I'm waiting on the carb adapter now from VI. Should be here tomorrow
BabyBird63
Post #31 by BabyBird63 » Mon Jul 06, 2020 8:46 pm
I hate it when threads fade away...
I've got a 1.01 and I'm waiting on my adapter. I wish I knew how this build turned out!
chad
Post #32 by chad » Tue Jul 07, 2020 1:16 am
he's still around. He takes PMs on his ford, not the Studie.
No thing has fadded away...
For U? will it go ona 170? 200 250? or what?
BabyBird63
Post #33 by BabyBird63 » Wed Jul 08, 2020 9:30 pm
It's a '66 casting 200, and the 1100 on it is past rebuilding. Phase 1 is to put the 2100 on an adapter while I hunt for a large log head and have it rebuilt and cut for a 2100 conversion plate. That is if I can set up the linkage and work out a kickdown for the C4 (currently none). Easy, right?
chad
direct mount a 2100. What jet size to use
Post #34 by chad » Thu Jul 09, 2020 1:10 am
U wanna direct mount a 2v? I like ur carb choice.
"...Easy, right?..."
Sure it's easy if U have a forge, horrozontal miller, and filling stock.
Some logs turn out better than others. U saw 1/2 way dwn page:
ci/LogMods.html#2VC
the 'grey' fill area?
drag-200stang
Re: direct mount a 2100. What jet size to use
Post #35 by drag-200stang » Thu Jul 09, 2020 9:54 am
chad wrote:U wanna direct mount a 2v? I like ur carb choice.
ci/LogMods.html#2VC
That is the beauty of the large log over the old small dog log, it does not need filling just thoughtful execution.
Just ask the OP of this thread.
66 Mustang Coupe
200 turbo w/lenco 4-spd
Went 9's when 10's was fast.
chad
2v direct mount and proceedure on 3 'different' logs
Post #36 by chad » Thu Jul 09, 2020 1:01 pm
more plez:
3 logs
best practices?
I understood all 3 needed a fill and a mill...
I got the "M" head just incase I do another i6.
drag-200stang
Re: 2v direct mount and proceedure on 3 'different' logs
Post #37 by drag-200stang » Fri Jul 10, 2020 10:02 am
chad wrote:more plez:
3 logs
best practices?
I got the "M" head just in case I do another i6.
I was just tying to reinforce that the large logs do not need filling if carefully planed out and this thread by Star covers it well.
viewtopic.php?f=1&t=79809
66 Mustang Coupe
chad
Best 2100 size to use on 2v direct mount 200
Post #38 by chad » Fri Jul 10, 2020 12:19 pm
I thought that thread had pretty conflicting reports "don't need filler" then a pic of 1 that really looked screwed/in need of filler...
Back to the topic.
I'm thinkin "no change" for a direct mount, "get one for the 200 v the 250" but defer to the experts.
wsa111
FSP Moderator
Post #39 by wsa111 » Sun Jul 12, 2020 7:37 pm
2V 2100 @ 3"HG. CFM
.98 = 190 CFM
1.01 =240 CFM
1.02 =245 CFM
1.08 = 287 CFM
1.14 = 300 CFM
1.21 = 351 CFM
1.23 = 356 CFM
1.33 = 424 CFM
Holley 7448-350 CFM
4412-500 CFM
Post #40 by xctasy » Sun Jul 12, 2020 8:23 pm
wsa111 wrote:2V 2100 @ 3"HG. CFM
.98 = 190 CFM
1.01 =240 CFM
1.02 =245 CFM
1.08 = 287 CFM
1.14 = 300 CFM
1.21 = 351 CFM
1.23 = 356 CFM
1.33 = 424 CFM
Holley 7448-350 CFM
4412-500 CFM
Fixed. :mrgreen: Not that you were eva wrong Sir
2V 2100 @ 3"HG. CFM
0.98 = 190 CFM
1.01 =240 CFM
1.02 =245 CFM
1.08 = 287 CFM
1.14 = 300 CFM
1.21 = 351 CFM
1.23 = 356 CFM
1.33 = 424 CFM
1.19 = Holley 7448-350 CFM
1.38 = Holley 4412-500 CFM
StarDiero75
Post #41 by StarDiero75 » Tue Jul 14, 2020 8:58 pm
Howdy guys,
Looks like someone brought this back from the dead.
So my VI adapter did not work well when I had it. After I did the 2V conversion to my head that same carb still ran like trash. The adapter might have been fine after all. I use a 1.08 now but its a different one. Runs pretty well. It does run richer than I'd like at certain times but rich is better than lean lol. Idle is rich and when the power valve opens before WOT it gets really rich, like high 10s. Theres a mod but I haven't had time and I'm kinda scared to ruin something that works haha. But I'm getting decent gas mileage if i keep my foot out of it. I was averaging like 24ish with a mild street cam and headers with this.
Hope it helps!
Ryan
chad
Post #42 by chad » Tue Jul 14, 2020 10:56 pm
I don't see any pic now. Did U use an adapter, which, 4 bots into the cast iron of the head? 3?
May B a different PV for the A/F correction (up 10).
Any leaks?
StarDiero75
Post #43 by StarDiero75 » Tue Jul 21, 2020 8:58 am
I had pictures. The custom adapter plate I made for my 2V had 4 mounting holes. They're kinda collinear with the straight parts of the slot. Maybe lightly in. I used allen cap screws and started with 3/4" aluminum block.
chad
Post #44 by chad » Thu Aug 13, 2020 10:43 pm
Hoe Kay,
thnx~
8)
Users browsing this forum: bubba22349 and 48 guests
