Great info thank you I really appreciate it,
I have a dumb question the input shaft on the manual transmission has 10 spline, how should I determine the spline count on the c4, I am sorry for my ignorance?
So you are very welcome, this is actually a great question that many people won't know answer too, here is how to ID the three different C4 input shafts.
The first Spline count on the 1964 to 1969 C4's is 24 X 24 on both ends the input shaft will pull right out of these early C4's. Also these use an input shaft that is the smallest diameter of .788 inch.
On the 1970 C4 the input shaft's strength was greatly improved by going to a .839 inch diameter it also had a 26 X 26 spline count on both ends, again these shafts will pull right out. This is a one year only design, it's a stronger Trans and is more desirable for any engine that's being built for higher performance use.
Now for the 1971 to 1981 C4's Ford changed the input again going to a 26 X 24 spline count like the theres the input shaft also pulls right out. They are the large .839 inch diameter. As with the above 1970 Trans these are even more perfered since there is also the most aftermarket support for these later C4's.
So with these above input shafts you can see that you need to use the correct Torque Convertor the early Trans it uses a 24 spline count with the smaller diameter. When checking this you can take your input shaft along to test the fit.The other later C4 transmission's will all use the 26 spline count with the larger diameter. It is possable to up grade the early Trans to this larger 26 spline count by using that larger input shaft, torque convertor and the later front pump assembly. But this is also why ts usally better and less expensive to go with the newer C4 Transmissions.
One other thing I should have mentioned before to be aware of when you are seaching for a C4 to do a swap is that there is also a larger version of the C4's that was made and used in the bigger cars and in pick ups / vans etc. These are know as the "Pan Fill C4's" these "Can Not" be used on any of the small block 144, 170, or most of the 200 six's short blocks made from 1960 to 1981, as there isn't a small six bolt pattern bell housing that's made to fit them. They will only bolt up to the 1969 to 1983 250 six engines or if you happen to have one of the very rare 1982 200 six big bell blocks that had a C5 Auto Trans originally.
Hi, I think the best bet would be to find a take out unit, maybe a complete drivetrain, from someone swapping to a V8.
If you stick with your engine line up the tin block plate and move the dowel pins to the new locations, and don't forget to remove the pilot bushing during the tranny swap.
Good luck
X2 I agree with all of what B Ron Co stated above except for this little difference that there is probably no need to move the short blocks dowel pins in this case. The OP stated that he has a 1965 Falcon if it still has the stock 1965 engine (all 1960 to 1965 Ford small six engines from the 144, 170, or 200 only had the single small bolt patteren blocks) and or if it still also had the stock 1965 2.77 3 speed manual Trans, then those manual bell housing are the exact same small bell housing bolt pattern as all the 1960 to 1981 Automatic Transmission Bell Housings used (i.e. the Ford O Matic or tge C4's). Best of luck on your swap. Edited
