Hi Kritas, the hole on the right in the second pic would not be plugged only the one on the left that goes into the SCV Port, the one in the middle isn't plugged either, if you plugged those two there wouldn't be any Vacuum coming from the Carb Base and going to the Threaded Distributor Vacuum Advance Port. The other two that you Plug up are inside where the SCV Port threads are you have that first one circled on the front plus there is another that is behind that. The goal is to only plug off the Upper Ventra Vacuum Source that was mixed in with Manifold Vacuum from the Carb Base with the SVC. You will only want to have the Manifold Vacuum Source from the Carb Base going up to the Distributor Advance Port when your done. If you are still have trouble seeing them all try using a small wire and run through those Vacuum Holes to see were they lead to, the only ones you need to have are those Yellow lines. Good LuckI pulled the carb and opened it up per the pics in the thread on modding it to remove the SCV ports. I wasn't prepared for finding a bunch of brown sludge in the fuel bowl since I pulled the carb after purchasing the car to perform all the bench adjustments on it that the PO didn't do. The carb was clean at that time. All that gunk has sneaked by the fuel filters in the handful of minutes that I've had the engine running. I'm going to need to drain the tank and check it. I have no idea what that gunk could be, but I haven't added any gas since buying the car-not running.
At any rate, here's two photos with the holes that I think need to be plugged circled. I want to make sure this is right because the pics in the original thread aren't very clear. I've also attached part of the original thread on modding the carb. Should the hole on the right in the second pic be plugged along with the one on the left, or is it the one in the middle that should be plugged? They are different sizes. Plugging the one on the right would seem to block all vacuum from the fitting going to the distributor.
