All Small Six Ford 200 Crank Stamps
Found a reman. 200 crank and vendor stated it has a 1H stamp. Looked for ID information on different stamps 1H, 1HA, E1BE, 3H but found no information. Can anyone comment on what these represent and which is most preferred?
Thanks in advance
Going into a 68 Bronco that once had a 170 ci engine.
Someone here will probably supply the answer but a call to one of the cam companies that do cams for our 170-250 engines could help.
The 200 is a good upgrade in your Bronco that was the first swap I made.
This forum member built a fast 200 with a Melling cam that is basically a stock grind if you are shopping for a cam.
Actually ENGINETECH ES658 is the cam he used.
He has provided some great videos.
At this point other than the four main crank we have not been able to tell if there is any difference in the cranks there may be but we cannot point out what it is. Let us know if you do.
