Fantastic! That’s what I will get then. Thanks for the posts and info Rabbit. Great l@@king engine you have there. I’m hoping to work on mine a bit as a fall/ winter project. I just can’t take this heat.Yes, same bolt pattern. Bolts right up to a '63 head.
You're welcome. Mrs Pickles deserves nothing but the best!Thanks for the info, but I think I’m going to buy a new one instead. My fear in buying used is that it may develop a crack due to age like the original one I have on my car now. Much appreciated though.
Yes she does. She’s a looker. Lol.You're welcome. Mrs Pickles deserves nothing but the best!
Thanks Bubba. That was what I feared.Be sure to start Soaking all the old Exhaust Manifold Bolts really good before you try to take it apart the Top one's are notorious for Braking off especially the end ones which seem to get a lot of exposure to the elements.
PB Blaster. Or Liquid wrench. Regardless, spray it over a week long period. It will burn off when driving. As engine cools, spray again for overnight soak. It's really beneficial to do an extended penetration period, with the heat cycles between applications.Thanks Bubba. That was what I feared.
WD40 or is there something better?
I’m baffled. Every one of those three manifolds list different year/car applications.Is this the same as the X manifold?
Try installing a header with turbo muffler. & a open air filter. note the duel header may give trouble with the startermotor tight fit . The org. Starter is a bit smaller than the newer starter also top Alt. Bracket may be the way.it seem that 63 comet feels like rans a lot BETTER 170 C.I. 3 SPD. 3:50 gears 15" wheels.I am new to Ford products and recently bought a 1963 Mercury Comet 4-door sedan with the 170cc inline six and Mercomatic trans.
I’m hoping to learn more about the car, performance, and possibly how to get more pep out of it.
It runs and drives great, but going up small hills I have it floored at it is sloooow.
I’m here to find out if that is normal with this drivetrain?
Thanks so much for any help with this and others in the future.
-Doug-
Now you are talking my language. That clears it up for me. So once I have that I can get a new 2” exhaust. I saw a setup on line of another comet. Single 2” pipe to the muffler, and then two pipes from the muffler out back.Do not worry they are baffled too. The engine came from ford with no gasket. You should use a gasket. All small six have the same exhaust ports and bolt patterns. You want a larger 2'' exhaust manifold. The one you posted is probably an offshore reproduction.
You pay your money and take your chances.
That’s the one Bubba! Don’t ever leave or boot me off of this site. I would be lost. Lol.MagnaFlow has one that is a 2 Inch Inlet with 2 X 2 Inch Outlets is a 5 X 8in. Oval Straight-Through Performance Exhaust Muffler #12128
Fully reversible and featuring a free-flowing, straight-through perforated stainless steel core, stainless mesh wraps our acoustic fiber fill to deliver a smooth, deep tone for your custom exhaust project.
MagnaFlow 5 X 8in. Oval Straight-Through Performance Exhaust Muffler 1
The MagnaFlow 5 X 8in. Oval Straight-Through Performance Exhaust Muffler 12128 is engineered to enhance your ride with a healthy helping of our signature exhaust sound and dyno-proven performance thanks to its free-flowing straight-through perforated stainless steel core wrapped in stainless...www.magnaflow.com
I think a few others will to maybe Walker.
Is that 3-speed a lot better than the Mercomatic? Or would it be best to wait for a C4?Try installing a header with turbo muffler. & a open air filter. note the duel header may give trouble with the startermotor tight fit . The org. Starter is a bit smaller than the newer starter also top Alt. Bracket may be the way.it seem that 63 comet feels like rans a lot BETTER 170 C.I. 3 SPD. 3:50 gears 15" wheels.
