WorkInProgress
I purchased a 67 vert about 3 months ago. I hired a local shop who was recommended by Dallas Mustang to address some mechanical issues. Some of the stuff was fixed, some was not.
I have done some research of previous post, and I cannot find a post that addresses the issue I am presently having.
Background:
1967 Mustang Convertible
Straight Six 200CI
C4 Tranny
Work done by local repair shop
Replace rear main seal
New oil pan and seal
New oil pump, Melling M65-B
New suspension and steering linkage
Still leaks oil. Shop told me it was impossible to totally eliminate oil leak. I get silver dollar size drops between motor and bell housing after highway driving. Reviewing this board I have learned the local shop was less than truthful with me, as there are several people have successfully eliminated oil leaks. The local shop also told me a high volume oil pump was installed. Via this board I have learned there is no high volume pump available. As a result I no longer believe what the local shop is telling me.
Work Done by me
Pony Carbs 1100
DUI Ignition System
Mechanical oil pressure gauge
Problem:
I am loosing oil pressure once motor reaches normal operating temperature. At cold start up oil pressure is 20 at fast idle If stopped at a stop sign it will drop to 0. At 2000 RPM (driving around speed) it is in the 15 to 20 PSI range. I changed the oil filter, thinking the oil filter might be clogged restricting oil flow and pressure. I pulled the DUI and ran the oil pump with a drill, 3,000 RPM, oil pressure never got over 30. Re-installed DUI, drove car around, same problem, no oil pressure when stopped with tranny in gear, 5 PSI with tranny in park. Limped it home, drained the oil, pulled the oil pan, pulled the oil pump. The oil pick up screen did have some loose RTV on the screen and some back stuff that was a solid, tiny rock size, maybe up to 1/8” in diameter. The black stuff would disintegrate when rubbing a piece between my fingers between my fingers. There was not a lot of stuff on the oil pickup screen. Less than 15% of the screen was obstructed.
The oil pump pressure release valve does not seem to be stuck open. I was able to move it back and forth with a small screwdriver, so I believe it is closed, as the pin that is the stop is hitting the inside of the oil pump. To get the valve to move I have to force a screw driver between the pin and the inside of the pump. Oil pump does look new. Oil pan is new and does not have a lot of sludge in the pan, just a speck or two of the above mentioned black stuff. Bottom end is not super clean, but does not have a tremendous amount of sludge. With the pan removed and the DUI installed I was able to confirm I have oil pump drive shaft at the pump and at the DUI, so I believe the pump is spinning.
Does anyone have an idea as to what I need to do?
Can I safely blow air back through the oil pressure sending unit hole in an attempt to blow out an obstruction?
Is there a way to rooter rooter out the oil passage inside the block?
Is it possible the new Melling pump was bad out of the box?
Several people have commented in other threads that scored bearings can lower oil pressure, but I am having a difficult time understanding how this is possible. The oil pressure sending unit is between the bearings and the pump. In my very small brain, I do not see how main bearings could affect oil pressure at the sending unit.
Any assistance would be most helpful.
Thank you
Background:
Straight Six 200CI
C4 Tranny
Work Done by me
Pony Carbs 1100
DUI Ignition System
Problem:
Thank you
