Good news, but mostly bad news...
good news, did a dyno run today, did see some improvement, but not nearly enough to to call it done...
HP=136
tq=166
I think air temp was around 90-95, I'll look later @ the dyno run...
this is with the cam degree'd properly, and the 2bbl directly mounted, A/F was rich, 11.5-12.8 ish, give or take ... but not enough to hurt the hp... the A/F was great throughout the entire range, so I do think I'm pumping enough gas...
I have developed another tick, or it's the same tick I heard last time just louder,
Fixing this while keeping it on the road everyday, this car/engine/hobby is getting to me guys, I love it don't get me wrong, it's just that this is by no means a daily driver anymore it's a daily fixer and this mechanic is getting over worked and extremely underpaid. my faith in the whole of the project is like $100 bills in a fire...
by the time I'm done with this car I could have had a 67 Convertible mustang for the 19k I have sunk into this one... mostly learning but gosh I wish I just bought one finished. hind-sight is always 20/20 vision...
I'm by no means done, I plan on getting this back up and reliable and tick-less...
I think my gas pump is ticking, so I'll replace that with a free electric pump I have access too. I don't think this is the main tick I'm hearing though.
the ticking is deff louder than last time, it wasn't ticking until after the dyno run, which I ran up to 5500rpm (1st time on dyno) it reved very smoothly even seamed to want to keep going
I plan on installing an oil gage, to tell me the exact oil pressure. it's possible that it's just inadequate oil pump.
I think I'm going to look for adjustible rockers and new push rods (getting the correct size push rod will be very important), I'm also going to drop the oil pan as it's leaking alittle, and while I'm there look at the oil pump, probably even replace it, while the oil pan is off I'll look at the camshaft while I rotate it, take pictures of anything that might look wrong.
Keep suggestions coming at things to look at, I don't mind being through, I'm even thinking of getting a 2nd block, pulling this one and putting eveything from 1st to the 2nd one part at a time, but I'll have to get a 2nd car before that happens.
Thanks guys.
