when i had my 500cfm, the car ran great, it will give you more top end pull, i just didnt like how my plugs would foul, the smell would make your eyes water, but it did pull more at higher speeds
Luke, I honestly think I have plenty of room, I have 50.5-51cc chambers now, as I'm using the 78 head, the desk is only @ .010 so milling the deck would be more difficult than it's worth. it's all in the head now. to get it up to 9.8 (I have roughly 9.25) I'll need .55 more, it equals out to roughly .050 off the head... think it can handle that.Luke76":26rg4t9d said:Rich, are you sure you can mill the head enough to get 9.8 CR?
Maybe you meant deck the block... I'm not sure there's enough material to remove on the head to get that high, but maybe I'm wrong.
Yeah...we could probably work out something to see if my carb would give you the 150hp you are looking for.MPGmustang":ubfd9o98 said:I think I know a guy that has a 500cfm on a well prep'd mav... maybe he'll let me try it on the dyno some day just for 'pete's sake' or even run a quarter mile with it some day...
I should ask... nah I'm sure he'll be curious and just hand me the carb and insist I run it!!!
what if...
I get the HHR, and run on the dyno with higher than 91oct gas?? with the higher oct will it 'act' almost like higher compresion with lower oct?
I reved the engine realy high lately the tach went past 6k!!! then a big 'BANG' (somewhere on the car IDK where from!) and loss of power, eventually with some cooling down and a day of rest she's back up to her normal power again I've also noticed a changed in MPG but that could be the fact I've been easy with her since... I think I should get a rev limiter to 5500 rpms for my DUI.
That's all??? :x wish it was more.... don't think it's worth it, I'll just put a rev limiter on itbubba22349":t8hm94hl said:should be able to pickup an additional 200 to 400 RPM
