Execute.
Thanks for comments. I didnt realise that a 5.8 ltre Falcon would have trouble beating a 8.5 0-62 mph second time. Im pleased with this.
After you recommended trying 4400 rpm instead of 4000 rpm changes I thought I would try it last night (with the leaking seal)
Before I went I checked the timing and because I have moded the xf elect dizzy to fit the 2V block the side clip was hitting it and forcing it r it to turn to further advance gave a noticable improvement in power and smoothness (Ill have to fix this properly somehow).
I then took myself 110 kg and my 250 2V Cortina (1150 kg in owners manual) and a quarter of a tank of fuel.
First time was 8.62 0-62 mph exactly as before. But 8 inch rear tyres had lots of spin in first and a bit in second.
Had to feather clutch very gently out and floor it to stop it spinning to get 8.42 sec time and another 8.41 in third gear. No bogging at all this time.
I will go up in jet size if 74s in 500 if 74s are holding me back as you suggest (what size whould I need if I had 220 hp 78 or 82 I wonder?).
Your figure of at least 155 hp at the flywheel to get 8.5 concures well with guy at Hume performance who had a 250 2V mild cam and 500 holley he said his made 124 hp to rear. Still good but a long way shy of 147 kw (at flywheel) that Dick Johnson said is possible (from one of your previous postings). That was said to be with a sub 270 degree cam and 500 holley with slightly moded alloy crossflow head. 115 to 120 kw to rear with same mods Ive got in a crossflow is nothing to laugh at.
Who needs a dyno with you around.
Regards
Thanks Heaps, Cheers
Regards
