TheAardvark
I have a 1964 8 door heavy duty automatic with the 170 in it. 100% stock from the factory.
I have nursed/coddled this baby along for the last 10 years, using it for short trips on cool days because of its overheating issues, most recently, the exhaust manifold has cracked and is leaking, so now I've decided it is time to fix everything at once.
I was thinking a frankenswap of engines from a running 75-82 Ford product with a 200/250 CI I6 would be the best bet, right? The current tranny is a C4, the mounts and everything should be the same, right?
I could use the wiring harness out of the donor car, and end up with an updated fuel injection / electronic ignition out of the deal, and maybe add in a remote starter.
These blocks should be compatible mounts and transmissions, right?
My other option is to remove the current engine, rebuild it, install a new exhaust manifold/header, add in a electronic ignition module and deal with the other issues (manual choke, draft tube, carburetor).
The other question I have for the experts is about the overheating. Should I upgrade the rad, or would upgrading to a flex fan be enough? Or even adding on an electric fan?
Thanks in advance,
Jeff
Winnipeg, MB Canada
[image]https://scontent-ord1-1.xx.fbcdn.net/v/t1.0-9/205105_217892401558497_6442884_n.jpg?oh=94d6d8948922a9f35cd1236a826f8561&oe=57DF7D8A[/image]
Thanks in advance,
Jeff
Winnipeg, MB Canada
