TheAardvark":2geox3h2 said:The 9" in the van has 4.11's. The 170 sounds like it is about to fly apart on the highway at 60. Will the 200 handle that better, or should I bring it down to 3.5's or 3.25's now that I have the bigger motor going in? Will a completely stock 200 push the van with a load with 3.25's and the C4 auto?
TheAardvark":2cusbj73 said:So, this kit would allow me to mill the intake manifold and adapt the 2 bbl, right? And this is the 2bbl of choice? Electric choke?
http://www.webercarbsdirect.com/product-p/wk663.htm
And then its just reworking the throttle linkages...
So, if I had to choose one modification, header or carb? I'm probably going to do both... but if just one, which one?
bubba22349":2vp0ktvt said:TheAardvark":2vp0ktvt said:So, this kit would allow me to mill the intake manifold and adapt the 2 bbl, right? And this is the 2bbl of choice? Electric choke?
That kit is designed for the 4 cylinder import cars and trucks yes those adapters won't fit a Ford 200 head without milling the head. They did work great on the numerous little 4 cylinder import engines that I used them on. If your budget is tight you could just use the late exhaust manafold and 1946 Holley carb thats already on your new engine. Plus it will have the DuraSpark II distributor just bolting it in as is going to be a great improvement over your 170. Good luck![]()
chad":2qzzjfqo said:think U need a short helper leaf if goin to the 1 tun loads?
RichC. & Seth?
