1965 Mustang, 200 ci... No Vacuum
i moved this here to get a better response.
ok no vacuum? if so the engine wont run except at very high rpms, like around 15,000 or so. are you sure you have your vacuum gauge hooked up properly?
How much was the head milled? Depending on the amount you might need some shorter push rods or you can try putting a set of washers the same thickness amount or close to the mill cut under the rocker stands. Have you done a compression test yet? :nod:
Hi, if you have adjustable rocker arms you could have set them too tight. Good luck
What does "no vacuum" mean in this case?
