Hi Everyone--I am new to the board and was reccomended here by the Stang.net guys. I am having trouble with a Ford 200 in a 1966 mustang
I just finished putting a long block in car. It fired right up and I was able to set the Dwell and Ignition timing and the idle mixture on the carb. However, the car idles extremely rough below 1000 rpm (my chiltons book says i should set the idle at 575 rpm and I cant get it below 800 without it stalling).
When driving and I come to a Stop--the car vibrates from the roughness A Tach shows that it also varys idle speed from 900 to 1100 rpm. The roughness smoothes out above 1000 rpm. The car accelerates and runs smoothly on the road. I have also put a vaccum guage ont the intake and it reads 14 lbs at idle.
I have the following new items on the car; fuel pump, (rebuilt carb), points/condensor, coil, spark plug wires,
I have checked for a vacuum leak by spraying carb cleaner all over and physically looking for a leak but cannot seem to get any response. Any thoughts as to what i should try next? Any help would be greatly appreciated. Thanks! --John
