Local rebuilder rebored the cylinders and rebuilt the head with new springs, guides, valves, seals and seats and turned the crank. I purchased the master rebuild kit that contains piston and rings, bearings, cam, lifters and all mounting gaskets. I installed the rings and pistons and I've lubed the crank journals and rod and main bearings and torqued the main bolts and rod nuts to the correct torque and I dipped the bolts and nuts in oil beforehand. Block is currently positioned on an engine stand, head has not been installed yet.
Question 1: Figuring out the oiling ring was easy, but the two compression rings---- I hope I installed them correctly. The top rings and the middle rings appeared to be the same width and both sets were marked with purple spray on the sides near the gaps. One set had a "stamped" dot about 1/2" from the gap and the other set had a "stamped" dot about 3/4" from the gap.Does it matter which ring groove I chose to install the rings in? I installed dot at 1/2" from gap in the top grooves.
Question 2: When I put my socket on the crank nut to turn it, I have to use a cheater pipe to get the crank to turn to see those pistons move. Is it normal on new rebuilds for it to take a lot of umph to turn the crank?
Question 3: My setup has the non-adjustable rockers and rocker shaft.
What is the correct order of installation? Lifters, then cam, then pushrods and finally rocker arm shaft? Do I just torque the shaft to the head according to spec and thats it?
Thanks.
Thanks.
