All Small Six 2 bolt starter swap for 200 w/manual trans
Hi, did you have any luck with this adapter?
Yes. I made two plastic prototypes and then an aluminum one. I test fit the metal one for fit, pinion depth & position, and everything looks perfect. I'm in the middle of welding new sheet metal in the engine bay (all 6 hood hinge mounting nuts were ripped out and U-nuts had been booger-welded in), but once that's done I will get the engine back together and get some real-world testing done on the starter with the custom adapter plate. Once I'm sure it's perfect and doesn't need any further modification, I will do an initial production run and make them available.
