claptonfan
I've got a couple of questions for you guys. The first is about the idle mixture screw of the autolite 1100. As I understand it, in = lean and out = rich. I just wanted to confirm this since i couldn't find a source online. The second question is about ignition timing. I adjusted my timing the other day, but I found that I could turn the distributor so that the mark on the balancer was far beyond the marks on the engine without any change in performance. Is that normal?
