MercuryMarc
I had my fan start at 190 and turn off at 170 (the turn off point is not adjustable separately - just 20 degrees below the on setting), and I had a 180 degree thermostat. Since the fan temp switch was mounted to a "T" fitting between the thermostat and the upper radiator inlet, the fan would turn on and never turn off!!! That was because the thermostat would close at 180 and then the hot fluid would remain at the "T" and would not recirculate, and never get below the 170 lower switch setting. I solved the problem by swapping in a 160 degree thermostat and setting the switch to kick in at 200 and off at 180 (it is variable between 170-180) but that way I won't get struck in an endless fan cycle. Pics of the above sete up availiable on the link mentioned in my previous emails.
Now I am not sure if I have selected an optimal operating temp but, doggone it, I am not going to overheat in a parade again!!!!!
Marc in SF
63 Comet Ragtop
200 ci/C4
etc...
Marc in SF
63 Comet Ragtop
200 ci/C4
etc...
