Well,
I just finished reading about my problem here is the forums. But my issue is a little different.
My engine was rebuilt around a 1972 Ford 200ci block because my previous block was cracked. I installed a new cam from clifford and did all the adjustments, I also have a petronix electronic distro. Along with the basic engine stuff, I purchased a 500cfm Holley carb to sit atop my beast!!.. haha.javascript:emoticon('
I had some basic problems with tooth allignment of my distro but I've sorted that out.
I got the engine finally running with the 500cfm Holley, but it was really bogged down and wouldn't accelerate at all. Plus, a thick haze of white smoke or fog was billowing from my exhaust. I decided that I should put my original carb back on and get the car broken in with that one. I re-attached the old carb and turned over the engine, a fountain of gasoline flooded out of a angled pipe inside the throttle body. I remembered that i removed what i think was a presure regulator from the inlet fitting.. it was a brass thing with some plastic thing on the side that goes into the carb inlet. So I purchased a $20 fuel regulator at Pepboys and hooked it up.. now it doesn't fountain as long as the psi is below 2.
The engine starts now and runs with the choke wide open and full throttle. Needless to say, it doesn't idle very well.javascript:emoticon('
I need to check my valves because I don't thing they are pre-loaded correctly.
Looking for some sugestions on what carb settings to use like jets and power valves for my 500cfm.. or should I just buy a 350cfm?
And.. what's the best way to hook up that carb with the linkage towards the front of the engine?
And... should I get a new timing gear set with adjustable advance for my cam?
