OK, many of you have heard me p*** and moan about the MGC engine being too small, too long, too tall, too heavy, and too underpowered for what I want it to do, so I'm replacing with a Ford engine that's less too small, still too long, still too tall, too heavy, and still too underpowered. So one thing I CAN do as I wait for the bills to repair the flood damage to clear is start evaluation one of the too's. TOO HEAVY
Dressed w/ a flex plate to crank pulley, carb to pan (no exhaust manifold), just how too heavy is it? As I picked it up, it had an alternator, PS pump, regulator, solenoid, and battery cables. First, this is an MGC, while someone in 'Urp makes a hydro PS for the car. IF it gets power steering I will go with an EPS. Less weight, and located closer to the center of mass. This would be no different if I kept the C engine, so it's kinda a push weight wise. So I stripped the harness' offa the engine (kept the coil, allt, plug wires.) Yarded the PS pump and bracket, hose stubs and clamps, emptied about a pounda squirrel nut's he'd stashed between the upper rad hose and the thermostat (pro tip- always check your nuts near your hose.)
So- drum roll please- as picked up, 445 lb (That's near 75 lb less than the MGC engine.) Strip off the PS pump and bracket and it's 421 lb. As crazy as this is to believe, this is about the weight that the C series engine was supposed to come in at, it came in a hundredweight heavy
