250 inline six newbie
64falcon":qwrzfe6x said:
Is there a right up on here about the direct mount for the 2v carb
the 2bbl is GREAT, but IMO it's not worth the money unless you're sticking around with the cast head... I put $1500 into my cast iron head, for more air flow, porting and valves etc... wish i put that into the alum head for only $600 more and I would have had 50more hp...
Just something to think about but if it runs ok just put it in and run it. If you have a 200 now you are probably looking at a trans swap which will take money, planning and time. Then you could decide if you want to put money in your 74 head which is not the late 77-81 head many look for because it flows more (larger log) or look for a later one. That is how my whole 1970 250 engine swap ended up and now I have purchased a complete late 1979 250 engine to build when I can get to it but no rush.
Ive actually thought about just cleaning it put a little dress up accessories and rebuilding the carb call it done be a lot cheaper and have more money toward body work and interior. Actually i may just keep the trans from the maverick.
what the guys taught me here (4 things) was that: 1st research was important and the 2nd & most important - application drives all the decisions on components, machining, etc (end goal). What I came to the automotive field w/ was a systems perspective so 3rd, 1 change 1 place will only wrk well if other prts of the system wrk well w/that. Finally, make all the decisions and stick w/them through out the build till completion (therefore if the research wuz incomplete ur ina lill trouble). Changing in the middle only makes a hodgepodge.
Anyway, those R ideas 4 me due to my lack of automotive theory, I'm a beginner in many ways. So experience is the best teacher. Give it a try, it's all just learning anyway. And U get a nice product outta it as well.
So, backin up: What is the application? DD? show car? strip bound? xx?
(I think it's a beginin project ride you'll do more research on while away & return to complete!)
8^0
BTW: this 4 prt plan totally leaves the $ question out, that's related to the research prt tho... ur ideal "dream" vehicle will B reduced by the sz a ur pocket book, 'course. Also - the research can't go on 4 ever, the project must start @ some point. These are 'balancing factors', eh? Money & time, money & time...
For the money, in order, I recommend:
1. Ignition - reuse the MSD, get new plugs, wires, cap, rotor. Upgrade to a duraspark $150
2. Carb - Autolite 2bbl on an adapter. Buy a used one, rebuild it. $150
3. Exhaust - used headers, duals (use a generic kit for a 66-67 Mustang) $450
4. If it's a 73 or later engine, use the 69-72 timing gears. The later engines have retarded cam timing to reduce NOx emissions, but lose a lot of power. $100
5. change the oil....
