I have a heat sink problem. It floods real bad such as trying to get back on the road after refueling. The other day while adjusting the wet float level as I turned the motor off, the fuel just boils right out into the venturis on a warm engine. I watched the entire contents boil away in two or so minutes. I have less than a 1/2 inch air cleaner hood clearance. There are two aluminum adaptors on it, one is the two barrel adaptor and the other is the Autolite adaptor. No luck find a carburetor heat shield for a two barrel; plenty out there for a four barrel. So, I'm thinking of getting a machinst to recreate the two barrel and the Autolite adaptor into one, which will give me plenty of room for a phenolic spacer. Or having the Autolite adaptor drilled out of a phenolic spacer...
Until I get this fixed all my mileage calculations & drivability tests are out the door.
This is the two barrel adaptor; the Autolite adaptor bolts to it. And here's the head with no adaptors:
A side view with carb and adaptors bolted up:
The two barrel adaptor is painted blue, so it's kind of hard to see.
viewtopic.php?f=1&t=63483
on getting very close
