Has anyone out there gone from the 50 cc accerator pump to the 30 cc pump on a 500 cfm 2300 holley on a log manifold. The same throttle bore & venturi diameter of 1 3/8 is used on a 750 cfm 4bbl using the 30 cc pump on the primary throttle. Just wondered if anyone had tried to down size the huge pump shot from the 50 cc pump shot. The 4bbl carb uses the white cam in #1 pump position which is the least amount of pump shot.
The 500 cfm 2300 holley was designed for a certain type of usage on large v-8's, which would require a large accerator pump shot.
Are we over shooting with the smaller engines such as a 200 or a 250 six??? Any thoughts or experience would be appreciated.
: William
