Crustang to Mustang
I'm trying to sort out my carb situation and I need to know, what is the overall cost of doing the Offenhauser 3x1 set up (give or take)?
"...had TWO intake adapters for the ThriftPower.How does the Offy attach to the intake log?
No that is for a small log, you have a 200/250 large flat top log.I know this Offy only says it's only for the 170ci and 200ci but it looks nicer than the one for the 250ci. Would it still work? https://www.vintageinlines.com/product-page/offenhauser-triple-manifold-adapter-1960-1968-1
Thank you.No that is for a small log, you have a 200/250 large flat top log.
Matt will take PMs on his site that guide ppl thru all sorts things. (He may C this'n respond here )I know this Offy only says it's only for the 170ci and 200ci but it looks nicer than the one for the 250ci. Would it still work? https://www.vintageinlines.com/product-page/offenhauser-triple-manifold-adapter-1960-1968-1
how tall is the assembly from top log surface to hood powerband? You did not have to use any 'hood raising tricks" w/those glass bowl 1904s?Nobody is going to do it for you 'turn-key'.
depending on your resources, abilities and availability, the 3 X 1 with an Offy adapter is 'mechanics illustrated' simple but requires an interested machinist ...
the hardware isn't too expensive - OFFY Adapter and linkage - 3 suitable carbs' - etc. less than $ 1000.oo ( and @ 1000 hours ) .
https://www.summitracing.com/parts/ofy-5970 ' -
3 offshore re-pops or 3 Webers ?
Autolite 1100 Carburetor For Ford 63-68 Mustang Falcon 6 cyl 170 200 Ci engines | eBay
Find many great new & used options and get the best deals for Autolite 1100 Carburetor For Ford 63-68 Mustang Falcon 6 cyl 170 200 Ci engines at the best online prices at eBay! Free shipping for many products!www.ebay.com
depending on your expectations, the rest of the engine can be OEM stock or modified to optimize the to your expectations.
