59 F100 223 head swap?
Folks,
I've heard that later 223 heads are higher compression. Is this true? If so, which heads will work on my '59 223. If not, how much can I plane my '59 head to jack up the compression. I'm trying to get a little more pulling power out of this engine. Any tips would be appreciated.
Thanks,
Brett
The head from the 1958 'A' code engine is rated at 8.6:1 and appears to be the highest stock CR available. This engine was used in the Courier and the Fairlane and rated at 145Hp.
