I have a 1981 Mustang with the late 200 in it. The car has A/C, PS, PB, and the emissions garbage, with a c4 auto. It only has about 77,000 miles on it, but it sat for 3 or 4 years right before I got it.
After a brake job, I've determined that the dampner or timing chain has slipped. The engine runs smooth at RPM, but has a hard time at slow speeds and idle. It also shuts off when going over hard bumps. Most importantly, it uses a pretty absurd amount of oil and I put a lot of miles on it. I am considering just doing a timing chain and head job on it, and seeing where I am at.
Ideally, I'd like to remove all the emissions garbage, put a header on it, put a progressive 2bbl on it, and a few other things. The car itself is mint with no rust or body damage.
Overall, I want to build this motor for maximum MPG, whatever that may be. My question is, is there a difference between this engine and the complete 200i6 I took out of my '71 Maverick? Can I just build the head on the maverick and then slap it on the mustang? Would this be optimal?
