What happen to the original intake?Hi, I have one of mikes aluminum heads on my 200. I need to fab a new intake manifold... I was hoping someone had a dimensioned file of the bolt ant ports on hand that i could use to cut my intake mounting flange from? Thanks
You get it done ? I can send you a picture of the one I have . I also have an intake for 3 side drafts . I don't think its finished yet though .I had the same thought ( scan gasket) but unfortunately the gasket is multiple pieces…. I’ve moved on to creating a file. I’
any on our site under the Index “cad files” ?Hi, I have one of mikes aluminum heads on my 200. I need to fab a new intake manifold... I was hoping someone had a dimensioned file of the bolt ant ports on hand that i could use to cut my intake mounting flange from? Thanks
Pls share photos if you can, of your process and results. I dont know fusion but know rhino3d/autocad2d.
You won't/ don't . I've ran a 2300 Sniper on the small log headed 200 6 in my 67 vert for about 6 years . The last 2 with a Paxton pushing in the juice, it's ran fine the whole time .here is the flange cut from 1/2" 6061. The files I made are done in solidworks, I shared the dxf. You should be able to view them with a free dxf viewer( edrawings might work) . Any cad program should be able to read them. I undersized the holes that need to be tapped. I have an econoline and can not use the standard intake manifold I have mandrel bent 90 degree tubes to go up, I am working on building a manifold to accept a holley sniper. I am not an expert on fuel injection but it seems I don't need to use equal length tubes to make the sniper work?![]()
IMG 2191 — Postimages
postimg.cc
Fwiw don't waste your time & money on an external fuel pump ,go intank pump. Also consider installing an electronic fuel pressure gauge inside where you can monitor the fuel pressure ,one under the hood is useless.You won't/ don't . I've ran a 2300 Sniper on the small log headed 200 6 in my 67 vert for about 6 years . The last 2 with a Paxton pushing in the juice, it's ran fine the whole time .
Very cool thanks for the image. I'll take a look at your dfx when i get to a computer. I don't have efi so hopefully sometime else can chime inhere is the flange cut from 1/2" 6061. The files I made are done in solidworks, I shared the dxf. You should be able to view them with a free dxf viewer( edrawings might work) . Any cad program should be able to read them. I undersized the holes that need to be tapped. I have an econoline and can not use the standard intake manifold I have mandrel bent 90 degree tubes to go up, I am working on building a manifold to accept a holley sniper. I am not an expert on fuel injection but it seems I don't need to use equal length tubes to make the sniper work?![]()
postimg.cc
