Have 1100 miles on engine, had new clay smith 274 camshaft & new gear on the distributor.
Lubricated both with moly lube & have run shell rotella with GM EOS since breaking in engine, yes the oil has been changed & the same oil as breakin are now in the engine.
How i noticed the problem, was i checked the timing with a timing light & found i had 34 degrees total & my initial advance had dropped to 14 degrees.
I pulled the cap & sure enough turning the rotor it had excessive play.
Proceeded to remove distributor & here is the gear & there is also some wear on the drive gear on the camshaft.
For the time being i just installed a new NAPA gear on the distributor & when i install the new head i will pull the engine & install another camshaft & this time i will use a crow cam's hardened distributor gear.
The gear that failed was a GP-Sorenson brand.
Where is the problem??? The cams or the distributor gears or both. Bill
There are some junk products out there but which one is the culprit??
