Since you are going with a custom piston you can order it with a large enough dish to have a low compression ratio using the 66 head.
You will need a piston with around a 10cc dish.
I don't see the need to cut off the intake log.
There's not enough to be gained with the small head and also considering the small turbocharger won't support high flow.
Instead do as much port work as you can and see about installing a larger intake valve.
Then open up the carburetor hole and mount a Holley Super Sniper two barrel throttle body injection unit.
Holley just brought EFI within range! Introducing Super Sniper EFI 2300! It's perfect for any vehicle that came standard with a 2300 Holley Flange like some Fairlanes, Galaxies, Falcons, Comets, F100s, Javelins, Rebels, Mustangs, Thunderbirds, Cougars and more. Looking to convert your blow thru...
www.holley.com
Then use an intercooler and consider running more than 10 lbs of boost.
The Super Sniper will support up to 21 lbs of boost.
Use the Holley Hyperspark distributer.
Do you need to upgrade your ignition system due to a recent Sniper EFI installation, but have no idea which option is best? Look no further than a Sniper EFI HyperSpark Distributor. HyperSpark distributors are plug and play with all Holley Sniper EFI systems, featuring a high quality billet...
www.holley.com
Along with the Hyperspark CD ignition
Do you need to upgrade your ignition system due to a recent Sniper EFI installation, but have no idea which option is best? Introducing HyperSpark Ignition, from Sniper EFI. The complete system consists of a CD Ignition Box, Billet distributor with Hall effect crank signal sensor, an ignition...
www.holley.com
And the Hyperspark Coil.
Do you need to upgrade your ignition system due to a recent Sniper EFI installation, but have no idea which option is best? Introducing HyperSpark Ignition, from Sniper EFI. The complete system consists of an ignition coil, CD ignition box, billet distributor with hall effect crank signal...
www.holley.com
