Howdy All:
Mark me in the column favoring electric fans over stock steel or aftermarket flex fans. I am still with a stock 4 blade steel fan on my 250. In addition to the advantages of electric fans already listed another use is that an electric fan, with a manual switch, can be used to cool the radiator and engine compartment even when the engine is not running. This would help to minimize heat soak at shut-off.
I did dig out an old Car Craft, 2/02 article, entitled "Electric Fan Dyno Test" by Matt King, where they chassis dyno tested a comparison of a '86 Mustang 5.0 with a OEM 5 blade flex fan to a Flex-a-lite Black Magic electric fan, rated a 14 amps draw when running. To quote, "saw a peak improvement of about 5 hp and 5 lb-ft of torque at the ear wheels. The power didn't just come at the peak either; the electric fan out powered the flex fan throughout the entire range of the dyno pull. That's not quite as much as we saw in our previous testing, but we'll take it."
The article did not say whether or not the fan came on during the dyno pulls or whether having the fan running added a greater pull from the extra load on the alternator.
The reference to previous testing was "Fan Power Test", May 00.
This article listed results from 3,500 rpm to 6,000 rpm. Greatest gains were at 3,750 and 4,750 rpms of 7 hp and 9 torque.
If anyone has gone the route of retro fitting a Taurus unit I'd sure like to see a new post on the process.
