67coupe200
Active member
theres multiple arcs
coming off the crankshaft pully when the engines running and i was wondering why.
67coupe200":10hdb334 said:.... and i was wondering why.
Weird.67coupe200":dz1r5mv8 said:...... i found a loose wire on the alternator, so I grounded it and now the arc on the balancer isn't showing........
Good catch, I overlooked that very important detailfordconvert":37j7h8hh said:Its been a while since I looked at my Ford's wiring but I dont recall anything on the alternator being grounded......
.By all means do so; there is no such thing as too much ground. I'm really puzzled about this stray sparking problem; you do need to make certain that the alternator is wired correctly and go from there.67coupe200":2bh589rs said:........ what if i run a ground wire from the block to the frame:
