Wait, what spring plates am I inspecting in the rear? I'm not sure what part that is.
The spider has 4 arms; only two of those have retaining clips, right? The front one has the other 2 pressed in, and the rear one has the other 2 retained by tiny u-bolts? I ask this because I distinctly recall seeing some spider "arms" without clips. They looked to be pressed in.
69.5Mav, I'm not sure that I follow. Are you saying that the grease fitting should be on the side of the spider that faces towards the rear of the car?
