spikeomatic
200 6 cyl,some where oil is leaking into my bell housing?? the pan is completely dry not one drop on the pan.it is engine oil .Head and valve cover are clean it has all new gaskets and a new rear main seal .it seems to be leaking between the block and trans somewhere ?has any one encountered this problem??the clucth and pressure plate are dry. could it be the flywheel bolts??
got some toyota FIPG sealant this time
