Well right when things look promising, you always find some other devil...
My shorter pushrods arrived from Mike today, that guy is fast! I couldn't wait to install them so I went straight to it. These are 3/8" shorter and are a much better fit. I tightened them loosely according to the procedure then cranked over the engine and let her run for about 10 minutes. This is the first time she's run in almost one year. The new exhaust sounded great, no bad sounds coming from the engine, everything was smooth as silk and I was very pleased.
I didn't drive the car anywhere, just let her warm up and I shut her down after about 10 minutes. At that point I popped the valve cover and started going through the procedure to tighten the rocker arm adjusters one by one while it was still hot.
In the process of doing this, I noticed some foreign object sticking out of one of the valve springs. I attached a picture of it below. It looks like part of the valve stem seal.
On closer inspection I saw similar matter on several valves. It is very hard to see between the spring coils, but at least one valve appeared to my bald eyes as if the stem might be bent. I will have to do a closer inspection tomorrow because it's getting dark and I'm too afraid to look any further tonight, my heart has already sunk pretty low already.
My thought is that last weekend when I had the pushrods that were too long, and I cranked the engine over several times, and bent the rods, that I might have also bent and/or damaged my valve stems somehow. Does anyone care to tell me what kind of s*hole I might be in if so? Maybe I am thinking the worst but if I bent the valve stems, I might have damaged the stem guide holes, and hence, toasted the entire head for all I know.
Any thoughts would be appreciated - or advice on what I should look for when I go back out tomorrow.
Material dangling out my valve spring (Click to Enlarge)
