Sorry guys for the slow response, weather here has been crappy and I haven't been able to motivate myself to go outside and fiddle with this thing.
I can confirm there is no rubbing/knocking on the valve cover, I've had it off several times and inspected the underside and the new rockers fit just fine with no banging. My oil pan also isn't dented but I haven't yet checked the oil pump, it's conceivable it could be making a noise but I am somewhat skeptical it's the cause of this one. Fuel pump is not the cause, you can put your ear right to it and that's not where The Sound is coming from.
Carb is probably definitely out of adjustment so regardless of The Sound I do need to work on that. That's a good idea to route a vacuum gauge so I can see it while driving, that might tell me something. (I don't have vacuum advance on the distributor though Rich, it's plugged off).
Yeah, exhaust leak is loud and obnoxious. That one's going to require me to pull the head again. If I decide I need to just pull the entire engine I'll just do it all at once this summer, assuming I find a garage.
So I still have some things to check. When we get another clear spell in the weather I'll get back to it.
Luke
Luke
