Well, I finally got my big re-build ready to go. I can't wait to post pics- it looked really good at first anyway. I painted the motor chrysler gold, polished the offy 3x1 set up and and cleaned and re-painted everything. I guess I bit off more than I could chew here because I did everything at once and now I have no baseline.
The carbs are new, the cam is new, the 3-row radiator is new, the thermostat and water pump are new, and the distributer is new.
I started out with with a 3 weber set up, and a Unilite mechanical advance distributer but since I couldn't tune them for anything I ended up blocking the outer carbs and installing my old Duraspark just to start simple and at least get it to run o.k. for the break-in period. So now I just have basically the same motor as before with a single weber 34ich and a new clifford 260h cam and bigger valves but I can't get the motor to idle reliably below about 1000 rpm and it seems to run a little hot at around 220 degrees.
My last set up was a weber 38dgas and I always tuned it by dropping the idle to around 500 and backing out the mixture screw until it was right.
This one I cant seem to get to idle that low so I have no idea where to set the mixture screw.
I know the cam is supposed to be a little rougher idle than the stock cam but I can't even sit at traffic lights without my foot on the brake if it has to be this high.
Any ideas what the problem may be? I put the biggest idle jet I have in there, which is a size 60, but it is hard to know what it should be if I can't set the idle down into tuning range. I set the timing same as always. And I checked for vacum leaks by spraying some starting fluid around and it all seemed good (though that offy adaptor could leak from the bottom and it would be hard to find). I always heard that leaks caused an up and down idle and this is just plain rough below 1500rpm or so.
Help guys- I couldn't have gotten this far without you all and now I need a little more educatin' to pull this thing off I guess.
