Well, even though you found a way to use the riser tube choke, I have my opinions on the original question.
Manual chokes all the way! Well, at least if you drive in the cold weather. My holley 390-4V carb has an electric choke that will soon be swapped for manual. Long and short of it is this. The electric choke I've found to be too finicky. If the temp is below 75* and the car is shut off for more then 10 minutes, the choke closes. That may be a result of the cooling system being new and the coated headers keeping it cooler in there now, but it's annoying. And forget driving down the highway when it's below 50*. at 70 MPH at 50*F the choke gets cooled down faster then it warms up from the heater element. It ends up closing even after the engine is normal operating temp.
Manual choke will allow me to adjust to the temps as needed. I've had them in the past and my only real obstacle is my wife as she's afraid of manaul chokes but I'll get her onboard and then swap it out.
Slade
