carb dieing going around turns
trashline
when ever i go around turns my car wants to die unless im on the gas . i just rebuilt the carb. and i adjusted the float level to factory specs. anybody with ideas?
What kind of carb is it? Some are more prone to this problem then others, but CobraSix is right, it sounds like a low float adjustment. This is usually not hard to misadjust by a small amount. Till you readjust it, slow way down in the turns.
sorry its an autolite 1100. yea i think its the float level too thats the only thjing i played with when i rebuilt the carb. but i was also wondering about the sproatic idele it has when it is the warm up process its fine if i drive it hard the the goes up to about 950 rpm if i drive it like a grandmom it stays around 750 any ideas? did it before and after the rebuild
