carb
stang65
Active member
hi i'm from mannheim ,germany and i have a 65 mustang coupe with a200cui 6banger from a 68 mustang
i want to put another carb on it which gives me a little more performance the car is a daily driver which carb could i take?
i have seen some at clifford and pony carbs but they are very expensive is there another source for carbs???
what weber, holley,carter or other does fit my 68 200cui inliner?
i have a used hooker header for this engine but no screws and gasket for it,someone told me i need special screws and aspecial gasket for it is this true and where can i get the parts?
Welcome. I'm about as far away from Germany as you can get!
Try finding a Ford Taunus/Capri/Granada 2.0 liter 4-cylinder ohc (1970-1983). Bressel/Weber 32/36. Some had return lines to the fuel tank. Pre 1976 ones may not have had a return line. These may be hard to find, as the TUV send old cars to the scrap metal dealer in Germany.
This is a nice size carburettor, and can be re-jetted to suit you six cylinder engine with ease. You may buy an adaptor to fit it, or make your own out of alumimum.
Its limit is about 125PS, which is all you can expect.
If you are unable to find one, you could use the 2.0V6, 2.3V6 or 2.8 carb, but its isn't as realiable as the 4-cylinder carb. It is harder to jet correctly, and doesn't have a staged secondary throttle like the Taunas ohc.
