Boy, Im cheesed off. What an epic!
The only way you can get 325hp + is with a carb better than a stock 500 cfm Holley. Ultra~flow have publicly quoted 290 hp with their intake manifold. With a full house 650 cfm 2-bbl, they'd be right. But these carbs a 'race' pieces.
Under exceptional circumstances, with a cam, compression and carb gas-flowed, I would concead 325 hp might be possible, but only on a race engine. It would be pulling a good deal of vacuum at wide open throttle, and would have no low speed tractablity, sort of like a NASCAR or AVESCO racer. All the anecdotal evidence is clear on this.
Eg. 1 The Barry Grant fuel systems have a gas flowed 2-bbl 500 cfm carb, either petrol or alcohol, with a set of 50 thou over bored throttles. Part number 4412S3B for gasoline, and 9647S3B for alcohol. The BG manual states for race only engines. Source: BG Fuel Systems Tech Mnaual and Catalog Vol 6, 1997.
Eg. 2 This follows on from the old days before 1980's, where there was a race only #2300 650 cfm 2-bbl (part number R-6425AAA) with the same throttle blades that Barry Grant uses, plus venturis bored out 62.5 thou and a Dominator style velocity stack. But it was for 400 cubic inch V8 engines, and in the build instructions it stated "not for use in engines running under 4000 rpm". Source:Super Tuning and Modifiying Holley Carburetors, by Dave Emanuel, upadted edition of 1988.
In both cases, these carbs were only 354 to 460 cfm stock. Gasflowed, they may be more, cetrainly the BG 500 flows more than 500 cfm at 3
"Hg. That's 220+ to 290 hp, tops.
Now this is what I propose you do. Buy the Ultra flow intake, and do what my next door neighbour did with his 265 Charger. There used to be a Carter 2-bbl to 650 #4175 (Rochester 4M Quadrajet rip-off) adaptor, made by Griffiths Speed in Auckland. It was about 20 mm tall, made of tooling plate alloy, and situated the secondaries right over the centre of the two barrel intake. The primaries discharged off centre, on to a lip over the front of the two-barrel carb flange.
It's okay, it worked really well. The 1974- 1978 V6 Mustangs and Capris used this set-up using the Weber 2-bbl carb, and it actually improved intake fuel distrubtion.
There is an issue, though. The 20 mm is enough to push the carb out the bonnet.
AlloyDave runs a 4-bbl on a Cain intake manifold. We've seen people modify the stock 2V to hack 500 cfm of Holley 4-bbl. Way back in a 1995 Street Machine article, Kev Bartlett ranked a 4-bbl 600 cfm Holley equiped cross flow as the second best engine to a 302 Windsor and a 351 Cleveland.
