I can't find the link or sticky that had the process for CC'ing the head and for the calculator to figure the comp ratio. I know the basic process, seal with grease or Vaseline, cover w/ plastic wth 2 holes, measure and fill with tranny fluid or oil.
After 6 months of fouled plugs=valve guide seals=pertronics failure= fuels system overhaul=duraspark install.... I'm finally at a leaking freeze plug on the cyl head. I figured I'd pull the head for access & while I had the head off I'd CC the chamber which I never did when I first rebuilt the motor.
Thanks!!
Thanks!!
