All Small Six Chasing vacuum leaks..the saga has ended.
ActionYobbo
I spent my whole weekend chasing vacuum leaks on a 1968 200 with c4 auto and a brake booster. It was what you could call running but it was not driveable. First leak was the rubber hose at the c4 modulator so that got replaced. Still not running better so I kept looking and found another leak at the brake booster where the hose was lose on the plastic plug. So I fixed that and it was running better but still could not get it to run under 1400 rpm. Then I find the pcv was stuck open so I replaced that. Now it won’t start. When it was running vacuum was between -15 and -18 when running and -7 when cranking. Now vacuum is 0 when cranking. When ot was running timing was fluctuating between 8 and 14 btdc.
The original carburetor was leaking fuel so I stuck on a rebuilt large bore 1100 with a 67 jet to get it running. Compression on all cylinders is close to 150. All tuning was done with the vacuum off the distributor.
So now it’s sitting in the driveway not running. It’s got fresh clean fuel, it’s got spark, timing was checked, all vacuum ports are now blocked. The motor spins but it’s got no vacuum.
Replaced the carburetor, fuel pump, fuel filter, fuel hose, hose at C4 modulator, distributor, coil, plugs, plug wires, engine oil, oil filter, water pump, belts, thermostat, and air filter
That’s my weekend roundup.
😵‍💫😵‍💫troubleshooting!!!
Just some more details, you said you could not get it to run below 1400 rpm. Would it die turning the idle down below that rpm? Or you can’t get the idle to go down below that?
Have you checked the timing? Verify you have spark.
I might think about putting the old carb back on. What distributor did you put in? Where is your vacuum guage hooked up to?
A lot of problems with new fuel pumps- verify fuel pressure
If you have compression you should have vacuum.
Not many suggestions but details matter
Don- he's got no vacuum and no start.
It won’t stay running below 1400 rpm.
Vacuum gage is under the carburetor where the pcv should go. The distributor..it had a LOM and I swapped that for another LOM that was a good running unit I recently took out of another build. Made no difference. Then I swapped it to an electronic ignition unit I used in this build https://fordsix.com/threads/log-int...-started-and-running.87033/page-2#post-722585
I got totally defeated yesterday chasing a vacuum leak and after thinking on it I did not check the freeze plugs on the ends of the manifold. I was finding very small leaks on old hoses and a faulty pcv but the more I fixed little leaks the leak kept getting worse so I am now I have all vacuum ports blocked and coated the carburetor base area with spray can white lithium grease and have no vacuum.
A starting place: pull distributor cap and verify it's turning. then verify the rotor is still positioned correctly with the crank (timing chain check)
If it did not run after changing the PCV valve, remove pcv line from the intake manifold and plug opening on the intake manifold for testing. Appears pcv valve could be defective, letting in to much air. To go from 7" of vacuum when cranking to 0 means air is getting into the manifold at a significant amount.
The best way to check for vacuum leaks is to remove and plug all vacuum attachments to the carb and manifold. This would only leaves the carb, carb base or the manifold. Spray with Carb cleaner to find leak. Engine will speed up if leak.
Check the carbs. Are the butterflies centered in the openings and closed all the way around when the idle set screw is backed out all the way?
I've rarely seen measurable vacuum while cranking. . . Thinking on this situation, something came to mind: it is possible for an engine to get so flooded that the plugs have a "gas gap" and don't fire. Assuming it has not jumped time (likely has not) I'd pull the plugs and verify they're not choked with raw gas.
the replacement carb- was it running with that carb before, or did the issue begin with the swap?
So it was barely running with the original carburetor that was leaking gas. I put on a rebuild and it ran the same. None of the parts I changed made it run better or worse. What did change how it ran was fixing or eliminating the vacuum leaks.
The more leaks I blocked the worse it got.
At one point I was spraying starting fluid into the carburetor when it was running at 1400 and it’s just ran faster up to 1800 with no change in the throttle position which is 2 turns of totally closed on the idle screw. Another odd this is the exhaust sound. It was making a hollow woop woop sound when it was running steady at 1400rpm
Results of today’s testing.
Took the carburetor off and blocked off the carburetor hole on the manifold so now there are no external holes in the manifold except the one I screwed an air fitting into. I pressurized the manifold with 60 pound of air pressure and looked for leaks with a soapy water spray bottle. No leaks were found. I took all the spark plugs out. They are all dry and straw colored from running lean. Did a compression test cold they are all at 125 to 130. Checked the timing on the distributor and cam on #1 inlet and exhaust. Distributor is set to 6btdc. #1 inlet closes around 40 degrees before the rotor points at 1 on the distributor
While doing these tests I had the rocker cover off and all the rockers move like they should and when a rocker is at rest I can spin the push rod.
Good diagnostics! . . I've no idea where to go from here. Only thing of note- #1 intake closes at aprox 40 rotor degrees before pointing to #1 tower. that's a good observation and may be fine since that is an estimated value. But if that were precise to TDC then the cam timing is late, as the intake should be closed well before 80*BTDC. Plus the odd exhaust noise- these are clues to what's the problem. But IDK where to go from here.
It does sound like the ignition timing is too low, providing your fuel is of adequate quality.
Was there any signs of it running hotter than normal?
Will the spark jump 5/16-3/8 inch from the plug wire to solid ground?
It’s running hot. Fuel is new I am running it from a hose stuck into a 5gal gas can of 87 that I filled up on Friday. Running a solid state HEI coil.
On the coming weekend I am going to fix the original carburetor and put it and the original distributor back in and see what happens.
Problems found and fixed. Here is the explanation broken down into 3 stages.
Stage 1 when I got the car it had 2 major vacuum leaks (trans and booster) and the carburetor was leaking gas.
Stage 2 I put on a carburetor that I got in a pile of parts I bought that I rebuilt (really just a clean and new gaskets and diaphragms) It has metric threads on the screws for the 2 halves. I found and fixed the vacuum leaks.
Stage 3 I was rebuilding the original carburetor by robbing parts out of the metric carburetor.( diaphragms, needle
& seat. etc) During this I realized there was no hole down to the idle mix screw on the metric carburetor so I put it in the drill press and made the hole. Put it back together, put it on the car and it runs like it should after setting the idle to 750 and timing to 6btdc.
Nice! Couldn't figure it was cam timing related, even though I kept throwing that out there. Carb- should'a known. :rolleyes:
Took it for a drive on Saturday. Seems a bit dead/sluggish getting going but it scooted along at 55 easily. Here is a picture of the plugs after 20 miles of highway and country roads.
The one on the left the porcelain looks "grainy", pitted. May be the pic. If it is that indicates too hot of a plug. The electrodes would suggest a decent air/fuel ratio.
So I took it out for a drive and it gets hot very quickly. I have a given it new 180 thermostat, new water pump, new aluminum radiator, timing is 6btdc (was 10 then 8 now 6) and it’s still overheating the same. AFR gauge is 10.7 at idle 800rpm and shows 11.5 while driving steady at 55mph. Cold It starts up and runs no choke (manual choke off). Hot also starts easily just turning the key with no pumping the gas or excessive cranking and will idle no issues except the getting hot and blowing out coolant.
I drove it 10 miles and it ran ok, a bit sluggish on acceleration but cruising along at 55 with ease. Sat at just under boiling the whole way.Spewed out coolant from the overflow when I turned it off. Let it sit for a few hours and topped off the radiator with almost a gallon of water and drove home and it ran the same as it did on the way out and dropped a puddle of coolant when I got home. If I can figure out this overheating bit it might be a good daily driver.
The mixture is rich, but you know that. Rich will cool the engine, lean heats it.
With all the new cooling components it should not be running hot. Not to nag, but are you positive your timing readings are accurate? I ask because late timing will cause an overheat condition. "sluggish on acceleration"- another late timing symptom.
I refrain from suggestions as much as possible- but if this were my engine doing this, I would begin advancing the timing a bit at the time and repeat the test drive. Forget a timing light; loosen the distributor lockdown bolt till it has slight drag, not all the way loose, then carefully move the distributor CCW till the vacuum advance can has moved 1/4". Hold it there, retighten the bolt and test drive. Keep doin this until there's pinging or no change in power. I predict improved performance and cooler temps. Once pinging is heard, retard the distributor 1/8" at the can till no pinging is audible. Don't retard it anymore, that is the correct timing.
If the temps refuse to come down, pull the thermostat completely. If it overheats then there's a flow issue somewhere.
